Friday was a good day, a pallet arrived from SC with my engine and all the parts from the kit, engine looks great in blue!
The head in all it's glory and the main parts from the kit, one pulley yet to arrive, should be in the post in the next day or two...
Pistons, pocketed and fitted to the rods and complete with ARP bolts...
Stainless manifold....
Jackshaft and crank which has been wedged bladed and balanced....
And a bunch of other parts all ready and waiting....
Meanwhile, not a lot has happened with the gearbox, I've been cleaning up and painting up the pinion cover and oil pickup pipe cover as they were horrible and rusty so will turn back to that in the coming days.
So while I was doing that I turned my attention to the engine. Inserted the jackshaft then on with the crank. Gave it all a blast with the air hose to ensure there's nothing lurking in any galleries and main bearings in place....
SC measured the crank journals for me and said standard bearings were what I needed so that's what I got, checked myself as well when it came back with the vernier, not the most accurate device but it did seem to be pretty much spot on according to the Haynes book of lies. Thought I'd give it a check with plastigauge though, I believe this is in tolerance (again accordion to Haynes), although at the top end, it stuck to the bearing rather than the crank which was a bit annoying as I had to be careful getting it off...
Crank and thrusts installed and end float checked, seems to be somewhere between 0.04 and 0.05 mm so probably a bit tight and thats with standard thrusts, couldn't really go any further anyway as I need my centre main strap to turn up from MED so I may take a smidge of the thrusts with wet and dry to get it within tolerance, I'm thinking too little end float probably is not a good thing!
So that's it for now....
