Bit of an update, I've been on holiday hence the lack of updates (I managed to miss all the snow and enjoy a bit of warmth in Malta!)....
So I have dropped the engine into the car, wasn't too tricky but I've learned a couple of little lessons for when I come to do this for real without damaging the paintwork, for example, have to fit the exhaust headers after installation, it won't go in with them in place (but they're not as difficult to fit afterwards as I had anticipated).
I've reasonable room front to back, I've set it as far back as I think is sensible for the time being (possibly, a touch too far), it's close to the bulkhead here but once the headers are wrapped it shouldn't be too much of I problem I think.....
And that leaves plenty of room up front, I think I've decided to fit the ITG sausage filter such as the one that SC sell and I'll probably have to modify the top of the front panel for it to fit and secure the bonnet with aero catches, but it will all fit!
The bonnet on the other hand does need a lot of work to fit, I started with my old rusty unit to practice, have slowly hacked away a the cross members and still not got to the end, looks like it needs practically the whole centre section removed.....
And it will need a small hump, even with the engine as far forward as I can get it it doesn't quite fit, I've cut a bit of a section and bent it up for now, it needs taking further in to the centre but actually it's sitting higher up than it really needs to be, engine only really pokes out bay 5 or 10 mm.
So now I'm torn, do I carry on with the experiment then transfer to the new bonnet and fabricate a bulge or go for something else, Carbon Weazel's products seem to be top notch but not cheap, the 16v bonnet looks neat. I'm now starting to think again about the final look of this car!
