Time for a bit of an update, nothing earth shattering but some progress test fitting the loom....
I ditched the SPI loom and purchased a late carb version on the advice of specialist components, this went off to Wired by Wilson for modification and upgrades, David did a fantastic job of customising my loom and I spent quite a lot of time working out how best to fit it around the bay so it's as tidy as possible, here's how it ended up....
Loom now has some new relays and fuses, I had all the glass fuses, including the inline fuses that would have lived dangling from the bulkhead and behind the dash swapped for blade fuses, as you can see they look nice and neat either size of the rotodip hole.
The relays I will mount to the side of the servo mounting, picture below shows test fitting, I've since made a bracket to fasten them to....
Loom needs a couple of minor tweaks and also I decided to add a couple of extra connections for auxiliary gauges so it's current back with David to finish it off for me, I can't speak highly enough of his work!
So with that the bulkhead an inner wings need some tidying up, I'd already decided to delete some holes that were not going to be required and I'd drilled a couple of extras I no longer need as I fiddled with the loom routing. Also one new 45mm hole behind the wiper motor where the ECU loom will run into the car, ECU to be mounted under the dash.
I also decided to do a final repair to the bulkhead, I'd patched it up a bit a long time ago but it wasn't great so cut out the dodgy patch and stitched some fresh steel in, it's now tidier and stiffer...
I've stocked up on rivnuts, which I'm using for fastening the P clips around the bay to fix the loom amongst other things, I also purchased a stainless bracket that the vacuum pump will mount to (wasn't cheap but it's very neat, so I've included some captive nuts that this will fit to, I've set it up so that it combines with the horn bracket as well to saves some space.
Here's how the bay now looks with the vacuum pump also test fitted again to check alignment of the captive nuts, thankfully they are good!
And the last thing I've done is work out mounting of my oil catch can under the wing, by coincidence a standard wiper motor strap fits perfectly around it and the can came with a single lug for mounting at the top. I fitted a small fixing poing for the lug and added a pair of M6 rivunts for the bracket to fit to....
And hey presto, it fits nicely, I may have it a tad high up, the filter may foul the fresh air pipe but that's easily solved....
So next up, fit the final A panel then onto the front panel that needs tidy up after cutting it back to fit the air filter and also rivnuts to be fitted to fix the front grille, also left to do are mounting points for alarm siren and vacuum tank and a small mod to the cross member to set it back a little where the exhaust header sits a bit close.
