hey folks,
only had this current mini for a few months, but it does this smokey startup about 50% of the time when started cold. I assumed it was just a puff of oil, but recently thought the colour and smell was not quite consisitent with that. Decided to investigate the possibility of brake fluid getting into the servo and then sucked up the servo hose into the intake, and guess what - there is a wee pool of fluid in there and the hose was wet with it on the inside.
I have cleaned out as much as I can with rags, and checked my fluid level - which has not gone down that I can tell. So I think it must be just a small leak. Does this indicate a leak in the master cylinder - ie worn seals?
The brakes are actually really good on this car and so far (touch wood) have not had any scary moments with them going soft or anything.
Advice on way forward ? Leave alone and monitor / replace master cylinder / rebuild with seal kit ?
Craig
