Well its quite a long list so basically I need to get new wings, front panel, windscreen surround lower panel, A panels for each side, bonnet, door skin and bottom inner repair plates for the doors.
Personally, i would go non genuine for the wings, front panel and A panel's
Definitely get a genuine Scuttle, the non genuine ones can cause leak's as the pressings don't fit to the windscreen rubber very well.
Bonnet, i would get a good second hand one
Door skins, non-genuine are fine but genuine are better
Bottom door frame repair panels are only available in non-genuine as far as i know
That's what i would do but it's down to you to get decide as it is your budget.
If you need door step panels, i would go genuine as they are the only ones that fit properly. Non-genuine ones are often folded wrong.
Give Doreen at M-machine a ring, they are very well priced, supply their own panels which they produce in house and the quality is brilliant.
That's where i get mine from
Ben
