Hiff Carb
Posted 24 November 2014 - 05:56 PM
Suposed to have a updated head but can't be sure also many a cam but again unsure of this
Posted 24 November 2014 - 06:37 PM
Posted 24 November 2014 - 07:37 PM
Posted 24 November 2014 - 07:51 PM
Hi
There should be a tag on the carburettor with some letters first then some numbers,
HIF 38 are normally starting with MAC, HIF44 are normally starting FZX, If it is a MAC it will have 5 Numbers or HIF44 and has FZX, it will be 4 numbers.
Failing that if you do not know if it is either, you will have to take it off and measure the inlet hole..
After this I can or maybe able to give you a needle size but rolling roads are the best way forward, trouble is they charge an arm and a leg and you get to see them rev the ******* out of your engine (painful) and you have to pay them to do this as well !!!!!!!!
Regards, Neil............................
Posted 24 November 2014 - 11:36 PM
Posted 25 November 2014 - 05:01 PM
if its an hif38 id say AAU (my 1993 1275 sprite(HiF38 carb) with polished inlet ports on the engine and stage one kit does your car have the spi tank and lines?
my car also has the charcoal canister under the left wing, vacuum advance routed via the thermostat housing sandwich plate
hope this helps
