Where Should I Mount The Head Unit - Mk1 Style Interior
6 replies to this topic
#1 LukeH
LukeH
  • 1,004 posts
Posted 25 November 2014 - 04:50 PM
I am going through the process of converting my R reg MPI to a centre speedo setup but I still want to retain a head unit somewhere in the car, although out of sight. I have a JVC head unit complete with remote control so I have the option of adding a IR repeater to enable the head unit to be hidden. I really do not like the under dash mounts and I won't really have room as I have relocated the relays and alarm ecu there. So far my ideas are;
1. Under rear seat in a custom panel
2. In boot - I have a boot liner so I could mount it in the side of the boot above rear wheel arch
Another idea is to ditch the head unit altogether and just go wireless with bluetooth and an amp.
Any suggestions?
Luke.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,017 posts
Posted 25 November 2014 - 06:33 PM
under the seat?
#3 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 25 November 2014 - 09:25 PM
If you want a project then mount the main unit under the driver seat but with the face in the drivers sun visor... A bit or work but damn cool when done...
Just flip it up and it's out of sight. :)
#4 LukeH
LukeH
  • 1,004 posts
Posted 25 November 2014 - 09:32 PM
Wow never thought of anything like that. Have you seen this done somewhere?
#5 LukeH
LukeH
  • 1,004 posts
Posted 25 November 2014 - 09:48 PM
Ruckus you are a genius.
I have googled this and it would be relatively easy to do by using some cat5 cable of which I have boxes of the stuff (work in IT) to make a ribbon cable linking facia to main unit.
I will experiment with facia position. Possibly sun visor or possibly some sort of flip-out from under the lower dash rail.
#6 Ruckus
Ruckus
    Ice Ice Baby!!!
  • 2,071 posts
  • Local Club: SMOC
Posted 28 November 2014 - 12:46 PM
I've did similar years ago with a blaupunkt New York headunit.
The 'Core' of the head unit was in the normal position in the dash, but it had a walnut blanking plate mounted to the original motorized face mechanism.
The face was mounted in the steering wheel!
#7 hellom8
hellom8
  • 188 posts
Posted 20 January 2015 - 01:04 PM
If you had space for a headunit, maybe consider a retro style head unit on display.
