Having Problem With Carb On A 1380
29 replies to this topic
#16 paul1380
paul1380
  • 124 posts
Posted 19 December 2014 - 02:43 PM
Ok i have found out the problem engine only running on two cylinders 2-3 1-4 not firing i have spark i have compression as i have run a compression test all cylinders are the same. I have changed the coil and dizzy but still same problem the only thing i can think is its the timing. I have recently changed the head gasket and have reset mt tappets.
Any ideas????
#17 mk1coopers
mk1coopers
  • 654 posts
Posted 19 December 2014 - 03:55 PM
I know it basic but have you checked the spark plug leads are in the correct position?
#18 paul1380
paul1380
  • 124 posts
Posted 19 December 2014 - 08:16 PM
yep just did that set up the timing marks made sure no:1 was no:1 i have been told it could be the amplifre module  on the dizzy.
#19 blackbelt1990
blackbelt1990
  • 2,605 posts
  • Local Club: Minimus Maximus
Posted 19 December 2014 - 08:42 PM
If you have a blue Haynes manual, it tells you how to test the amplification module in the troubleshooting!
#20 paul1380
paul1380
  • 124 posts
Posted 19 December 2014 - 09:34 PM
i do thanks for the information :)
#21 blacktulip
blacktulip
  • 6,221 posts
Posted 19 December 2014 - 10:04 PM
Do you want to keep these carbs? Are you open to change? If so then I would personally go with the hif44 or the weber as a single carb.
#22 paul1380
paul1380
  • 124 posts
Posted 19 December 2014 - 11:05 PM
I have the weber on at the mo and I think i'll run it on that just need to sort this electrical problem out so I can get them jetted.
#23 paul1380
paul1380
  • 124 posts
Posted 21 December 2014 - 12:53 PM
Ok think I have found the problem seeing as my wiring loom has a pink/white wire which is a ballast resistor wire which is connected to the coil it isn't preducing 12v when running only 9v so I am not getting a bigger enough spark when running hence why I might only be firing on two cylinders fingers crossed this is the problem :)
#24 paul1380
paul1380
  • 124 posts
Posted 21 December 2014 - 01:28 PM
Right just disconnected the white/pink wire from the coil and connected a 12v feed to the coil and it made matters worse only fired in one cylinder so will wait for the new amplifier and hope it will sort it....😠
#25 paul1380
paul1380
  • 124 posts
Posted 22 December 2014 - 10:27 PM
NO! no joy new amplifier connected and still the same problem i have run a separate 12 volt feed straight to the amplifier and a 12 volt feed to the coil.
has Anyone got any ideas?
Edited by paul1380, 22 December 2014 - 11:17 PM.
#26 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,824 posts
  • Local Club: man Estate
Posted 23 December 2014 - 11:01 AM
If you posted this in the technical section you will get a better response from the tech wizards on the site.  Have you looked through the electrical section of the FAQs?
#27 paul1380
paul1380
  • 124 posts
Posted 23 December 2014 - 03:27 PM
Not yet but will do thanks.
#28 mk1leg
mk1leg
  • 9,341 posts
Posted 23 December 2014 - 11:34 PM
have you checked the leads are in correct order....1-3-4-2 in anticlockwise rotation with no: 1 lead at 2oclock......
:highfive:
#29 paul1380
paul1380
  • 124 posts
Posted 24 December 2014 - 12:06 PM
yes done that all ok there going to double check the valves are closing properly and going to try a different dizzy cap and coil as well.
I have changed the plugs the leads the rotor arm the amplifier module double checked the tappet gap.
#30 DB1380
DB1380
  • Just Joined
  • 55 posts
Posted 24 September 2020 - 03:23 PM
Old thread revival.....
Paul, did you ever get to the bottom of this problem ?
DickyB.
