1982 Austin Mini 1380
67 replies to this topic
#1 CPC
CPC
  • 235 posts
Posted 16 December 2014 - 11:14 AM
Hi Guys
Just thought id start this thread and keep to up to date with the highs and lows of my Mini.
I bought this car in July time after seing it listed on Ebay & Pistonheads the spec from the advert
1982 Austin Mini shell. De-bumpered and all welding / panels in need of replacing have been prior to paint prep.
Sprayed Mazda Winning Blue (lovely pearl paint)  with pearl white miglia arches and roof.  MK1 Cooper grille.
1380cc road/race engine (Only 600 miles done so far!)
Runs brilliantly! Would be good to get it on a rolling road to refine the SU needle and also confirm the 100bhp / 100ft lbs of torque this engine should produce!
Work carried out by Rob Walker Engineering on the block:
  • overbore cylinder block
  • reface cylinder block
  • new cam bearings
  • centre main strap
  • regrind cracnkshaft
  • balance 4 cylinder crank
  • balance rods and pistons
73.5mm 11cc DISH MEGA PISTONS
SW10 Duplex timing kit
Swiftune SW10 (286) Billet Camshaft
11 ARP head studs
HIF44 carb - rebuilt and reconditioned
Stage 4 cylinder head
K&N filter
Power flow oil pump
Rebuilt and reconditioned gearbox - no expense spared
Central oil pick up
New clutch (orange diaphragm) - clutch and flywheel balanced professionally
Facet solid state fuel pump
Custom loom and Megajolt Lite Jr ECU timing - makes a world of difference!
4 x Ultralite 7x13 extreme wheels with Yohohama A539 tyres (new)
Fletcher Stainless Steel LCB Back exhaust system
Maniflow Exhaust Manifold - heat wrapped
Silicon hose kit all round
Halogen headlights
Reconditioned front disc brakes and rear drums
Braided brake hoses
New brake and clutch master cylinders
Brake bias valve
Union Jack headlining
After a decent clean and at a car show
More of the not so good stuff to follow!
Chris.
#2 CPC
CPC
  • 235 posts
Posted 16 December 2014 - 11:32 AM
Continued..
Some of the not so good stuff and what i wish id researched before buying it! but i can all be sorted!
On the drive home with the car i noticed a missfire and poor running from the engine and if im honest i did not know how to sort this so carefully drove the car upto Sleaford Mini Centre who adjusted the mapping and carb mixture and got it running well.  It made 80bhp at the wheels that i believe is approx 96/98bhp at the flywheel?
I also had some electrical issues and turned out to be a damaged conection in this birdsnest of wiring
#3 CPC
CPC
  • 235 posts
Posted 16 December 2014 - 11:37 AM
I was never happy with the look of the white wheel arches so painted them myself.
wide wheels!!!
Screw driver fixing!!
After that i thought id go for some custom made side decals
#4 CPC
CPC
  • 235 posts
Posted 16 December 2014 - 11:45 AM
My car has always felt very loose on the road and with the big wheels this highlighted the issue, it turns out i had a bent tierod and all suspension bushes and rubber subframe mounts were totally shot!  I then placed a order with Minispares for a set of adjustable tierods and lower arms with new polybushes and the solid metal subframe mounting kit they do.. this has really helped the car but i still need to get the alinement set.
This trackrod end would not tighten so i had to cut it off!, i have replaced them with the longer trackrod ends that you require the the lower arms
20141205_143728.jpg.
Whilst doing this work i noticed this damaged fuel line
i have replaced this now, but ever since the engine feels flat with a slight miss.  So i guess this has upset the mixture and i need another dyno visit?
This brings me upto date for now..
Edited by CPC, 16 December 2014 - 11:56 AM.
#5 CPC
CPC
  • 235 posts
Posted 19 December 2014 - 02:39 PM
Just found out the reason for my bad clutch pedal and the need to pump it before it would cleanly select gears, looks like its only the slave cylinder leaking, fingers crossed!
#6 StefanPieter
StefanPieter
  • 131 posts
  • Local Club: FDMC
Posted 19 December 2014 - 11:14 PM
It seems like you have a nice little car there. What are your plans with her going forward?
#7 CPC
CPC
  • 235 posts
Posted 20 December 2014 - 09:38 PM
Lots of plans, the main items
the whole front end could do with a respray due to some dents and poor paintwork
replace the shocks and cones ( the front cones are buggered!! then everything will be new suspension wise)
a set of retro type bucket seats and a rear roll cage
Then ive been having thoughts of swapping the wheels for a set of 10x6 wheels with sticky yoko tyres
#8 CPC
CPC
  • 235 posts
Posted 17 March 2015 - 09:15 AM
Just taxed it again this weekend after its winter storage, it needed a jump start but fired straight up!
10989031_10155260426530184_5363947497857
#9 !3UMBLEBEE
!3UMBLEBEE
  • 82 posts
Posted 17 March 2015 - 11:08 AM
Looking really nice! U doing l2b this year. Be good to see in person.
#10 CPC
CPC
  • 235 posts
Posted 18 May 2015 - 12:32 PM
Finally got round to sorting the suspension out!, this weekend i fitted Minispares red dot cones, Gaz lowered shocks and Hilos and they have transformed how it drives! plus its no longer riding on the bumpstops!!
#11 CPC
CPC
  • 235 posts
Posted 12 August 2015 - 09:17 AM
Due to a high crankcase pressure and smoking i have decided to strip and remove this engine, its a real shame as its only done around 2000miles!
Any one of the last pics in its current forum
11058112_867423013350216_380464482094952
And last few nights progress, ive never removed a engine before so its all learning!
11822726_10155858989905184_2588392364838
11870642_10155858991360184_3335967673372
11825745_10155867655945184_3695554951491
I don't really know what to do engine wise, stick with the A-series or maybe a Vauxhall or K series conversion?
Edited by CPC, 12 August 2015 - 09:46 AM.
#12 CPC
CPC
  • 235 posts
Posted 17 August 2015 - 10:47 AM
More stripping down
11887860_10155880942760184_5535583891520
Removing the interior to tackle the oversills of death!!
11905386_10155880943155184_5474258261354
11221884_10155880943545184_7704181041337
11855816_10155880944125184_5468387164998
Fingers crossed its not too bad!
#13 CPC
CPC
  • 235 posts
Posted 20 August 2015 - 10:01 AM
More work required!!
this is at the top corner of the inner arch A post/flitch join
And Ive removed the offside oversill, its all fairly solid but been bodged, a welded section at the rear inner sill, no jacking point and for some reason the cross member section is open
Not sure what to do about this yet until i have removed the other side!
#14 CPC
CPC
  • 235 posts
Posted 25 August 2015 - 07:54 AM
This is turning into a full rebuild!! noticed the oversill rust!
I also got grinder happy! the panels were held together with rust!
Plenty of fun ahead!
Chris
Edited by CPC, 25 August 2015 - 07:56 AM.
#15 StefanPieter
StefanPieter
  • 131 posts
  • Local Club: FDMC
Posted 25 August 2015 - 04:42 PM
It's amazing how a project escalates from a quick job to a full rebuild.
