:wales: When I bought my engine it came with a dizzy so I assumed it was a turbo one, how can I tell if it is?
Turbo Dizzy
redmini
, Jul 07 2004 05:12 PM
14 replies to this topic
Posted 07 July 2004 - 05:12 PM
Posted 10 July 2004 - 02:11 PM
the vac addvance pulls 12 deg not 7 and has a hevey duty slip spring in it
Posted 10 July 2004 - 10:06 PM
:wales: is there no easy way like a model number or something? The one I have has a module on the side if that's of any use :grin:
Posted 10 July 2004 - 10:13 PM
the pic below is of my turbo dizzy, the model number on it is...
41932D 59DM4 ....} 0883
hope this help mate.
Posted 10 July 2004 - 10:18 PM
:wales: Cheers, I'll take a look tomorrow
Posted 11 July 2004 - 01:14 AM
The mk1 dizzy has the seperate module, the mk2 has the module mounted on the side.
I have several dizzys and they all have different no.s, i think what fireman-sam says is true & maybe the only way of telling.
Phil.
Phil.
Posted 25 July 2004 - 12:13 PM
sorry i dont have a pic of a mk2 dizzy but the vac add has a diffrent number stamped on it and that tell you how much add it pulls hope that helps
Posted 25 July 2004 - 07:21 PM
:wales: excellent, I'll have a look when I get a moment thanks. Any idea what the number should be and where abouts it's stamped?
Posted 28 July 2004 - 10:25 PM
if you open up the dizzy and take out the vac add it is stamped on the part that moves in and out
but you can only see the number if you pull the dizzy to bits :smartass:
Posted 26 August 2004 - 09:41 PM
hi i no what the numbers are now for the mk2 dizzy
the vac will say 12 not the word nine
and on the bob wieghts its 10 not 13.5
Posted 27 August 2004 - 08:26 PM
:wales: Cheers mate, got my dizzy in bits infront of me now and it says "nine" on the vacuum unit...... Explains a lot, anyone got a spare turbo dizzy? :sad:
Posted 03 September 2004 - 10:52 PM
if a mk1 one will do yes i do he is going to put it on ebay but his gtm turbo will be on the club stand at mitp he could take it there if that helps
Posted 04 September 2004 - 05:17 AM
:wales: redmini 's computor is down , I was talking to him the other day and he is now desperate for a turbe dizzy , He will be at MITP with us lot :wales: See you there :grin:
Posted 09 September 2004 - 10:09 AM
:wales: I'm back................ :grin: but how long before it goes up the wall this time :sad: :erm: :wink:
I'm ideally after a mk2 dizzy and am hoping to pick one up at mitp, thanks for the help though guys
Posted 17 September 2004 - 06:54 PM
:wales: Mitp saw me acquiring a standard turbo dizzy for £15 and as Fireman-sam has previously said, the vacuum unit has the numbers 12 stamped on the control arm and the bob weights are stamped 10 (which he showed me in person at mitp, cheers matey :grin: I did check myself as best as I could with the tools I had but F/s totally had it in bits)
Anyway thanks for all the help you've all given me and hopefully my engine will be developing full power sometime soon, I'll keep you up to speed on "Turbo nut" :cheese:
