Cylinder Compressions
Posted 20 December 2014 - 06:04 PM
cylinder 1 120psi
cylinder 2 110psi
cylinder 3 110psi
cylinder 4 130psi
Can any one advise if I have any issues from these pressures. All four rose quickly once engine cranked.
I think it is burning oil, its also leaking as well but that's another job.
Stephen
Posted 20 December 2014 - 06:07 PM
Posted 20 December 2014 - 06:09 PM
Those figures, whilst not very different for each cylinder, are a bit on the low side.
The first question is were the measurements taken whilst cranking with all the plugs out and the throttle(s) fully open?
If they were, then I would get a leak down test done to check the piston ring condition.
It is unlikely to be a valve seating issue as that normally just affects one cylinder where an exhaust is on the way out. Consistently low figures do indicate bore wear.
Also try running the engine fully warm at tickover with the oil filler cap removed. If it 'chuffs' smoke out that is an indication of worn bores.
Posted 20 December 2014 - 06:57 PM
Posted 20 December 2014 - 07:03 PM
Add a drop of oil in each cylinder then carry out the compression test again, if the pressure increases then its the rings. If nothing changes then the valves need to be lapped in again. However this can also be down to damaged seats / valves so a strip down will be needed.
Posted 20 December 2014 - 07:15 PM
Posted 20 December 2014 - 07:44 PM
Westlin - if these are compression pressures correctly measure then I think you have issues.
For guidance, my 1293 running about 9.5:1 CR was between 185-190 psi. This was measured after getting the engine up to full working temperature.
The last 1275 engine which I had readings down as low as 110-130 psi (when measured 'cold') turned out to have all of the top compression rings in multiple pieces, and bores were very worn. Mind you, it had been used hard...
Posted 20 December 2014 - 08:08 PM
is there a documented set if pressures, haynes has not got them.
Posted 20 December 2014 - 08:24 PM
it was not run after the rebuild as far as im aware, if it was the rest of the car was not up to it.
Posted 22 December 2014 - 12:27 PM
Cylinder initial with oil
1 120 psi 130 psi
2 105 psi 115 psi
3 108 psi 112 psi
4 130 psi 135 psi
this tine I let the pressure stablise before noting it down. As I mentioned earlier in the thread and I dont know if this makes any difference, it has been rebored and new pistons and has only done as far as im aware about 60 miles since being changed.
let me know your thoughts.
thanks
Posted 22 December 2014 - 12:37 PM
As it is a fresh build/running in scenario I've another suggestion.
Running in should generally be done on something with a low/poor APi rating (C or D), if lubrication is good the rings never bed in and this could be the source of your low compression readings. Run in on cheap, low grade 20/50 and then move to something decent once the period of running in is complete. And don't be afraid to give the engine some load/beans to really get the thing run in - extend rpm.
It may be hard to imagine, but even your "light" oil might be too good.
Max variation across the cylinders should be 10-15psi.
Edited by fwdracer, 22 December 2014 - 12:46 PM.
Posted 22 December 2014 - 12:48 PM
Get some more mileage on the bottom end but if the figures do not rise then it could be the bores are glazed and will need re honing.
Posted 22 December 2014 - 12:58 PM
thanks
Posted 22 December 2014 - 01:13 PM
Edited by fwdracer, 22 December 2014 - 01:28 PM.
Posted 22 December 2014 - 02:15 PM
Headgasket gone between 2 and 3 (typical 1275 - use a BK450 HG).
Poor rings seal, i dont know if you measured bore clearance and tolerancies but for now check mixture, if too rich then rings will never bed in properly due to bore wash.
