Hi Steve did you get my message regarding the door frame ?
2000 Cooper Sportspack Turbo
#286
Posted 23 November 2017 - 07:10 AM
#287
Posted 23 November 2017 - 09:35 AM
Yes chap, not sure why I didnt respond
#288
Posted 02 December 2017 - 12:39 PM
Update on the bodywork! Decided to get the sand blaster out and get the corrosion out of the hard to reach areas. Also wire wheeled all the corrosion sealant off the bulkhead and sprayed with Electrox
Plugged a few pin holes
Also found a bit of corrosion on the top of the A pillar
Filled the doors with Electrox
Sprayed up the seat brackets
And finally the spot lights! These were a bit rough around the edges - Overspray, polish, scratches etc.
First time the car has seen daylight for a while!
#289
Posted 02 December 2017 - 01:49 PM
Good to see you've got back some enthusiasm for it.
#290
Posted 02 December 2017 - 03:59 PM
only 1 thing to say Wow what a great read and well done on all the hard work so far
#291
Posted 02 December 2017 - 06:14 PM
Looking good Steve
Keep at it it’s coming together nicely
Mark
#292
Posted 02 December 2017 - 09:35 PM
#293
Posted 02 December 2017 - 10:27 PM
#294
Posted 02 December 2017 - 11:00 PM
#295
Posted 03 December 2017 - 06:16 PM
What sandblaster are you using Steve? Ive got the same job on front bulkhead to do aswell
Im using a cheap one I got off eBay and medium weight glass media. I used a wire wheel on the bulkhead and the blaster for the hard to reach areas.
#296
Posted 12 December 2017 - 04:49 PM
Moving on with more bodywork! Got the grill to sit properly after some experimenting and the addition of some rivnuts!
More rivnuts installed!
A big thanks to Sean (Shifty) for lending me a cylinder head to get on with some engine work! Got the turbo installed and some modification with a cutting disk and a flapper wheel.
choppy choppy!
At least there's light between the turbo and the block!
Looking to put the oil drain here
And looking to put the actuator here - just need to get hold of a TIG welder or someone that can do it for me!
Edited by Steve220, 12 December 2017 - 04:54 PM.
#297
Posted 12 December 2017 - 04:59 PM
Loving that turbo!
#298
Posted 12 December 2017 - 07:32 PM
Stop it Steve, you are giving me bad ideas for my MPI
#299
Posted 12 December 2017 - 08:09 PM
Mwuhahaha!!! <rubs hands together>Stop it Steve, you are giving me bad ideas for my MPI
#300
Posted 14 December 2017 - 09:32 PM
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
