Yep Plus the wife is as work I use the part cleaner loads
replacement fob case was from ebay. Just got a delivery from Magnecor and Minisport Finally i can get it all put back together :)
Posted 21 January 2015 - 06:40 PM
Posted 21 January 2015 - 08:13 PM
Cracking on with this mate!
Going to be one fine mini once it's sorted out looking at what you have achieved so far.
I'm with you on the wheels and roof, glad they are changing
Posted 21 January 2015 - 08:16 PM
Would you mind sharing the seller you bought it from? I'd be interested in buying a replacement case too.
Posted 21 January 2015 - 08:18 PM
eBay i expect.
This one is for other Rover models but i expect they are the same
http://www.ebay.co.u...=item19db095d09
Posted 21 January 2015 - 08:21 PM
eBay i expect.
That's the one thank you - just wanted to make sure I bought the right one
Posted 21 January 2015 - 08:58 PM
http://www.ebay.co.u...=item2a221766c9
Is the exact one i bought :)
Guys, bit of a problem. I was cleaning the engine as its COVERED in oil/grease (found out the rocker cover bolts were finger tight :-/ ) and saw that the stabilizer bush on the right handside (as you look at the engine from the front) is shot, the engine rocks back and forth a fair bit. As i see the general consensus is that the engine mounts maybe shot too, so looks like i'm going to make myself busy over the next few days!
Posted 26 January 2015 - 12:08 PM
Posted 27 January 2015 - 12:20 PM
Cracking looking Mini. Mine will looklike that again one day As regards to the throttle body, ive heard the 52mm Mgf alloy one is a direct replacement, as long as you swap the original throttle position sensor over too. Has anybody tried this?
Posted 27 January 2015 - 12:35 PM
its not a direct swap, fair bit of fiddling, for ultimately no benefit
Posted 27 January 2015 - 01:52 PM
Posted 27 January 2015 - 02:02 PM
sadly the mems cant be mapped....
Posted 27 January 2015 - 02:55 PM
Posted 27 January 2015 - 06:27 PM
I agree; the mems is a good bit of kit, really clever
Posted 27 January 2015 - 06:57 PM
Mems is good till the day something goes wrong, then you hate it... (talking from experience aha)
Sykes Pickavant reader is a must with an MPi
Posted 27 January 2015 - 07:32 PM
Don't say that! I'm dreading something going wrong on mine...
Edited by CCX, 27 January 2015 - 07:32 PM.
