I've been doing a lot of bodyshop and mechanical work recently which has only strengthened my love of cutting things up and welding them back together.
As I have decent size project coming up soon I decided make my self a Mini fronted sofa to help get myself back into fab work.
I've seen these made from FG flip fronts but they always seem too bulky for a single seat so I'm making mine from a steel front and stretching to make a 2 seater.
My first job was to remove the bumper lip and number plate brackets. I've also removed the subframe mountings from the rear.
Then chop down the middle! I guess this panel wont be going onto a car anymore.
I settled on adding 50CM to the centre of the valance which will result in a 120CM seat base, just a bit wider than a Mini rear seat. I haven't got a slip roll so I formed the curve over a few different tubes and a giant roll of paper.
Before I went home I decided to see what it looked like with wings clamped on and I must say I'm pretty pleased so far. The seat is just for reference and the finished article will be higher off the ground and have A-panels and scuttle corners fitted to tidy the back edge up.
