I've installed an 'emergency fuel cutoff' switch - next to a start button
I also have a flashing LED (white) next to the switch.
When I flick the emergency switch (and the fuel pump audibly stops) The LED flashes as a kind of 'warning' light due to an emergency situation.
Somehow I wired it up and it worked exactly right. I don't know how!
Anyway I had to do some rewiring and part of this involved the flashing LED.
The flash in LED is quite simple as a unit - provide it with 12v and earth the other terminal and off it goes.
However I want it to flash when I flick the emergency switch (which cuts the circuit for the fuel pump)
How on earth do I supply power to the flashing LED light when another circuit is switched off?
Confused!
If anyone can think of a way I'd be very appreciative
Steve
