In a few weeks I plan to give the car a good service,
I was just wondering what parts people use, like whats the best oil, best spark plugs, do people replace the sump plug or just the washer etc...
Thanks David
Posted 30 January 2015 - 12:38 AM
Thanks David
Posted 30 January 2015 - 08:43 AM
Oil, I use halfords as its just down the road
Any of these:
http://www.halfords....ic-oil-20w50-5l
http://www.amazon.co...r/dp/B002RPJ67E
Oil filter:
http://www.eurocarparts.com/oil-filter
Type your reg in and it will do the work for you, You can use these for the spark plugs too! or look here
http://www.theminifo...-choice-advice/
You only need to change the washer for servicing, although I ran out last time I did one so cleaned and reused the old one with no porblems!
As I service mine regularly I order 5-10 of these at a time:
Also clean/replace your air filer depending on the age!
Hope this helps!
Posted 30 January 2015 - 11:17 AM
Posted 30 January 2015 - 12:13 PM
I've found my timing gun to be very useful.
Posted 30 January 2015 - 04:00 PM
Posted 30 January 2015 - 10:58 PM
thanks guys, will get purchasing!
