Rim Difference - Maybe A Stupid Question.
Best Answer Yams , 05 February 2015 - 10:47 PM
Nope they are different, They have a different offset. Reverse rims will fit without arches cooper s won't.
reverse rim has a lower offset, i'll figure out how much more it pokes by.
Edit:
Just checked, 10x4.5 reverse rims have an offset of ET16 but the 10x3.5 standard wheels from the 60's have ET 29 and the 70's ET24.
This would mean the reverse rims will extrude by 26mm over the 60's 10x3.5 steels and 21mm over the 70s steels.
Go to the full post
5 replies to this topic
#1 RobbieP
RobbieP
  • 73 posts
Posted 04 February 2015 - 06:43 PM
I've been looking at running 10x4.5 steel wheels over Cooper S brakes. My question is, are "reverse rims" actually the same as the 4.5x10 Cooper S steel wheels? There are so many pictures on sites of wheels claiming to be Cooper S 4.5x10's and some are listed as "reverse".
help?
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 04 February 2015 - 07:37 PM
#3 Tupers
Tupers
  • 4,176 posts
Posted 04 February 2015 - 07:51 PM
Other way around Alex, reverse rims are a wider offset the standard S wheels.
These are 4.5" Cooper S wheels. A reverse rim uses the same outer hoop but put on backward to make a deep dish wheel.
#4 timmy850
timmy850
  • 3,602 posts
  • Local Club: MITG
Posted 05 February 2015 - 09:38 PM
I've got a set of reverse rims for my car. They fit perfectly without arches with flat drum brakes front and back. You'd definitely need arches fitted if you used them with disc brakes.
#5 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 05 February 2015 - 10:37 PM
off topic.... but this is beautiful!!!!!
#6 Yams
Yams
  • 644 posts
Posted 05 February 2015 - 10:47 PM   Best Answer
Edit:
Edited by Yams, 05 February 2015 - 11:04 PM.
