4 Synchro S/c C/r Gear Kit
Posted 21 February 2015 - 05:28 PM
Shooter
Posted 21 February 2015 - 07:56 PM
Posted 25 February 2015 - 02:41 PM
Posted 25 February 2015 - 07:37 PM
It'll depend on the type of rod-change box, won't it?
A-series (remote or rod) would have the same diameter layshaft? A-series vs A+ would have different diameter layshaft?
Posted 25 February 2015 - 08:04 PM
yep, to the best of my recolection
all A series use the same third motion shaft ( the 1st motion to 3rd motion bearing is different on the A+)
reverse is different between rod and remote box's due to the selector.
putting a series gears into an A+ box can be done, but you need to file the case to clear the 1st to 3rd motion bearing as the early small diameter A series one is longer.
Posted 25 February 2015 - 10:19 PM
I concur, A series into A+ case can be done, just need to relieve the case a little over the 1st motion bearing to allow the fitment of the longer A series mainshaft.
You will, however, have to change the reverse idler from a remote to a rod, this is not the standard reverse idler but unique to the ST gearset, still available part number c-str303 (£52 ish)
