Details of the car:
Registered on the island of Jersey from new until 40,000 miles in 2010 (we have all the details of the import and registration)
Now has 50k on the clock.
New wheels
New crank sensor
New coil pack
12 months MOT (New rear wheel cylinders and brake shoes, swivel joints and knuckle joints)
New reconditioned Gearbox, gasket set & oil filter (1000 miles ago)
Lambda sensor and cat and link pipe done 7000 miles ago.
New refurbished ECU and immobiliser unit.
New Horn
Theres a small amount of bubbling on the doors and on one corner of the windscreen, standard mini stuff, not bad but worth mentioning.
Basically the car went in for some bodywork before we were going to sell the car and for whatever reason developed an electrical issue where the car would cut out randomly and occasionally the alarm or horn would signal.
That mechanic tried his best to fix whatever the problem was and - we suspect - he may have buggered up the wiring loom.
After that we sent it to a really well renowned mini garage, they tried all sorts, we even spent money replacing the ecu and immobiliser because they identified that as the fault but it turned out that didn't end up working either.
The fault is intermittent so the car can give the impression that it's 100% but then the fault occurs. That caused us to give the go ahead on all the MOT work and we've really invested a lot into this little car.
In the end the mini garage cut and removed some wires from the loom to try and bypass the alarm or immobiliser unit. This worked and we picked up the car but after the 1 hour journey home, she was up to her old tricks... Back to square one.
Basically all this car needs is a new loom. We have found someone on this forum who has kindly offered to fit it for us at our home address but we also need to source one and as you can tell from what's been done to this car we've spent 1000s of pounds and we are coming to you guys to see whether it might be worth giving it to someone else to replace rather than waste any more money.
How much do you reckon we can get for it with this fault?
Also how much would the car be worth IF we were to replace the loom and it was working?
The car will run fine but the fault is very intermittent so it could cut out and be immobilised for hours. It's a right headache!!!
Thank you so much,
Regards,
The Kelly Brothers
image.jpg 83.33K 29 downloads image.jpg 89.93K 25 downloads image.jpg 58.98K 25 downloads image.jpg 56.15K 21 downloads image.jpg 125.27K 18 downloads
Edited by Equinox1275, 27 February 2015 - 02:04 PM.
