How Do You Fit Those Chrome Window Seal Strips
Best Answer Cooperman , 28 February 2015 - 01:24 PM
When you tap the strip onto the clips make sure the window glass is wound fully down. I had a window glass which was about 1 mm too high and when I tapped it with a rubber mallet, guess what. DOH :shy: .
Go to the full post
4 replies to this topic
#1 M111OWW
M111OWW
    Woody
  • 126 posts
Posted 28 February 2015 - 01:06 PM
Quick question, how do you fit those chrome window sealing strips that go on the inside and outside of a wind up window door?
Do you push the clips on first....or slide the clips into the moulding then push the whole lot on together..
#2 fwdracer
fwdracer
  • 269 posts
  • Local Club: Mini7 Racing Club
Posted 28 February 2015 - 01:09 PM
Slide clips into channel - equally space them with one at each end and then push down firmly. Persuade with a rubber mallet if needed.
#3 Cooperman
  • 23,039 posts
Posted 28 February 2015 - 01:24 PM   Best Answer
#4 M111OWW
M111OWW
    Woody
  • 126 posts
Posted 28 February 2015 - 01:26 PM
So would you fit the clips onto the door first then push the moulding over the top?
#5 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 28 February 2015 - 03:05 PM
You swore ha
