Converting 1984 'duel Clock' To Central Clock
Posted 06 March 2015 - 01:56 PM
I have a 1984 Mayfair and wanted to convert the standard 2 clock dash to a single central clock. Can anyone tell me if this is:
1 possible?
2 straightforward?
3 where I can get info on how to do it?
Thanks in advance
Chris
Posted 06 March 2015 - 02:00 PM
You can get the wiring to convert it. http://www.minispare...|Back to search
Quite a few threads on it
http://www.theminifo...-centre-speedo/
Posted 06 March 2015 - 02:01 PM
It is certainly possible.
As far as i know, you need to buy a central speedo and the housing (second hand) and then you can buy a wiring harness to convert your existing wiring to accept the new speedo.
I'm not sure if you would need to change the speedo cable or not though.
Then you will need the centre speedo dash liner cards to finish the job unless you have a wooden or other dash to go in.
Here is the wiring harness
https://www.minispar...|Back to search
and here are the dash liner cards
The speedo itself can be purchased new also but they are quite pricey
Ben
