Hi Guys
Its been a while since i have posted on here and been a while since i have used my car, Ascari coming up in June so well its one not to miss, anyway after blowing up my gearbox a year ago or so i have been gradually swapping out and building a new box over the last few months, just bought a new Redtop 30 battery, cleaned the TB,s and fired her up yesterday started fine but only run the car for 10 mins or so not enough time for the engine to get to temp, today i had the car running for 40 mins all the fans cut in out temp sitting at 90/92 all sweet so it seemed, turned off the engine now i can't get her start just cranks over, any ideas i haven't looked at anything yet thought someone could shed some light 1st.....
This is what i do know if it helps.....
fuel in tank
fuel rail cold as if it has fuel in it
new coil pack used for an hour last year
new battery yesterday and charged
alternator at 1,4v+
crank sensor runs of the cams for the Hydra ECM ( The car i have is the very 1st Vtec built by Zcars was Chris personal car no 93)
not sure if they still use the crank sensor for the pick up for the ECU.
new plugs
new leads
Fuel pressure at 3,5 bar more or less running on an open loop so no fuel tank back vac pressure
any ideas!!
Shady
