Supercharger Questions
Posted 08 March 2015 - 03:22 PM
Posted 08 March 2015 - 05:00 PM
You don't need a return fuel line but it would be advisable to swap the mechanical pump for an electric one to keep up with the increased fuel demand.
The suck through superchargers have a belt tensioner bolted onto the side but nothing modified internally.
Posted 09 March 2015 - 10:08 PM
You do need to modify the supercharger internally, otherwise the flow out of the manifold would be vastly restricted....
Posted 10 March 2015 - 01:19 AM
Care to elaborate?
Posted 10 March 2015 - 05:17 PM
Steve, I'm making a kit at the mo, picy's to follow!!!
Posted 08 April 2015 - 12:27 PM
With that chunk taken out can you still use the original bmw mini steel gasket?
Edited by HUBBA.HUBBA, 08 April 2015 - 12:30 PM.
Posted 11 April 2015 - 07:12 PM
Out of interest, why is your outlet hole there? Most kits are more central so no need to modify the bottom of the charger.
You can't put the outlet hole more central to the supercharger, otherwise the pulley won't line up with the crank pulley, and the pipe work between each inlet port to the head won't be equal. Do you have pictures of other inlet manifolds??
Posted 11 April 2015 - 07:17 PM
You can't put the outlet hole more central to the supercharger, otherwise the pulley won't line up with the crank pulley, and the pipe work between each inlet port to the head won't be equal. Do you have pictures of other inlet manifolds??Out of interest, why is your outlet hole there? Most kits are more central so no need to modify the bottom of the charger.
Look at side entrance manifolds, such as Evo's, supras etc, they don't have to be equal to the ports. Not by a long shot.
Posted 12 April 2015 - 06:54 PM
Edited by HUBBA.HUBBA, 12 April 2015 - 06:56 PM.
Posted 12 April 2015 - 07:59 PM
Just picked up my eaton charger, can't wait to get it fitted!
Posted 13 April 2015 - 07:49 PM
I knowIt will not make a difference.
Posted 14 April 2015 - 12:02 PM
Posted 15 April 2015 - 07:14 PM
I'll have an inlet manifold made up this week for this setup, with a proper merge collector where the inlet pipes join. I'm not sure why they all have such a small opening when the blower outlet is so much bigger? Plenty of scope to improve the flow out of the blower. I'm trying to get hold of an SC to get some dimensions of the outlet to make something up, and also configure it for blow though too.
Just had a look on you facebook page. The bits and pieces look good. Are you building a 16v blow through set up?
