Alloy fins: £80
Based in the west midlands for collection
Posted 12 March 2015 - 07:12 PM
Alloy fins: £80
Posted 13 March 2015 - 01:55 PM
Posted 13 March 2015 - 05:26 PM
Hi would you post the headlining bars ?
Posted 13 March 2015 - 05:46 PM
The heater is it plug and play or is it a job to plumb it in etc
Is it a stright swap for the original heater?
Thanks paul
Hi Paul K. It is one that will have to be plumbed in and wired up as it is a normal heater but as far as it goes it isn't a massively hard job as pretty much everything you would need would already be there from the previous mini heater (providing you have one )
Posted 13 March 2015 - 05:47 PM
I would but only to UK address's and p&p would have to be worked out. Regards Blue
Posted 13 March 2015 - 07:32 PM
Edited by paulk 7364, 13 March 2015 - 07:34 PM.
Posted 14 March 2015 - 09:03 AM
Hello blue blood . Where in the West Midlands are you, if you are close to me (stoke on Trent)
I could come to you, is it possible you could install
The heater in my car?
Could you send pics as well please
I am only based in Stourbridge. As for installation i would not want to do it as I would not want to do something wrong to your vehicle and be held liable as i am not an insured mechanic or anything. I hope you understand. I can get a picture later but I got it from car builder solution.
This type: http://www.carbuilde...43kw-car-heater
Then had a custom stainless steel cage bracket made for it and a custom real carbon fibre facia cut for it.
Posted 14 March 2015 - 09:05 AM
Do you know if the indicator lamps would work on an mpi? I.e. Are the connectors the same? Also how much for the headlamps? Can't see a price... Cheers
I believe it will work as I was going to use my MPI wiring loom on them but don't quote me on that it might have different connectors (easy enough to change though with a souldering iron)
Posted 14 March 2015 - 11:03 AM
ok let me know how much it will be
Posted 14 March 2015 - 01:18 PM
Hi, How much posted to the UK at my risk for the Clear lens Wipac lights.
Thanks Dave.
Posted 17 March 2015 - 06:50 PM
Here are the pictures of the heater unit and custom brushed satin stainless bracket (not some flimsy aluminium unit) with neoprene lining and a custom made real carbon fibre facia to make it all look pretty. Come with all wires, connectors, zip ties and control knob. All brand new.
Posted 28 March 2015 - 12:35 PM
Still have the hubs?
Posted 28 March 2015 - 02:02 PM
Posted 28 March 2015 - 07:20 PM
Hi Dom I still have the front hardened hubs for sale.
