Were To Cut
Posted 12 March 2015 - 09:09 PM
Posted 12 March 2015 - 10:00 PM
I'd suggest you to test fit the frame into the shell before painting ;)
Posted 12 March 2015 - 10:07 PM
Posted 13 March 2015 - 07:18 AM
I would suggest that if no-one gets back to you with the dimension that you CALL Zcars as there ability to reply to emails appears limited, after reading people complaining about it on here. The dimension is on one of the build DVD's they produced but I havent got a clue where mine is......
FYI if, like me, you have a built car its not easy to jut go and measure what you require, also they may have changed the frame slightly which could mean a current owner giving you the wrong info and no-one would like to do that.
Get on the blower and get it from the horses mouth - they don't bite....
PS - I concur with Andrea, get it test fitted and all your cutting sorted before painting it but also dont leave it in primer, as primer is porous.
