Spare Standard 1275 Standard Piston Oil Control Ring Anyone ?
7 replies to this topic
#1 Flatrightout
Flatrightout
  • 41 posts
Posted 27 March 2015 - 06:28 PM
Hi all, just fitted new standard size 1275 piston rings and managed to break a oil control ring, ( bottom one ) don't spose anyone has a spare ring to avoid me buying a full of rings cus they don't sell them individually.
Thanks for reading
#2 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 27 March 2015 - 06:38 PM
You might be able to buy a piston set from Mini Spares?
#3 Flatrightout
Flatrightout
  • 41 posts
Posted 27 March 2015 - 06:53 PM
[quote name="Flatrightout" post="3239893" timestamp="1427480911"]Hi all, just fitted new standard size 1275 piston rings and managed to break a oil control ring, ( bottom one ) don't spose anyone has a spare ring to avoid me buying a full set of rings
#4 Flatrightout
Flatrightout
  • 41 posts
Posted 27 March 2015 - 06:54 PM
They sell full sets only, ( 4 off ) already phoned mini spares
#5 Spider
  • 13,925 posts
Posted 27 March 2015 - 08:33 PM
I would be VERY cautious about obtaining a single ring, be it compression or oil control. Be dead set sure that it's not only the same brand, but also for the same Ring Pack.
The Rings are designed as a pack to work together. Mixing them can have unexpected results, like either a smoker or something that will wear the bore in no time flat. That was how I learnt this, the hard way. I'd broken a Ring and used another, within 10 000 km, it needed a re-bore as it had worn on that single cylinder, while the others were perfect.
#6 MrBounce
MrBounce
  • 2,563 posts
Posted 27 March 2015 - 09:26 PM
Your best bet would be to have a chat with a local engineering shop who may have some NOS stuff hidden away somewhere. I did exactly what you did when building my engine and managed to get a set of rings for a knockdown price from there. I was then able to sell the remaining rings on ebay.
It might be worth giving Mini Sport a ring as I have heard that they sell rings in single piston sets. :gimme:
#7 Cooperman
  • 23,039 posts
Posted 28 March 2015 - 12:05 AM
Might be cheaper to buy a piston, depending on the piston part number.
#8 Flatrightout
Flatrightout
  • 41 posts
Posted 28 March 2015 - 05:51 AM
Thanks for replys guys, ok looks like I need to get a new ring or piston set or......
Put the old oil control ring back on, with the new compression rings. what's your thoughts on this ? Block has been homed,
Many thanks
