i just did a bit of digging on the mini :L
what panels should i get?
Posted 29 March 2015 - 09:39 PM
Posted 29 March 2015 - 09:47 PM
Posted 29 March 2015 - 10:06 PM
Outer sill, door step, A post, flitch panel and on the rear quarter either a full quarter panel or the lower repair section.
I would bite the bullet and get the Heritage A post and door step combo. You may also need the inner part of the A post as well.
this will be the first time ive welded,
should i weld a brace bar in?
and what should i start with?
do the all the other bits first and the the sill last?
Posted 29 March 2015 - 10:15 PM
ive got this so far
sill
http://minispares.co...ic/14A9534.aspx
door step and rear quarter
http://minispares.co...sic/MSL28R.aspx
and this
http://minispares.co...ALA6472GEN.aspx
is that the bare minimum i need?
Posted 30 March 2015 - 05:45 AM
Posted 30 March 2015 - 09:43 AM
A panel off then start with the flitch. This will let you then get on with the A post.
Put a brace across the door aperture for the door step.
Outer sill last. What you have got will give you a good start but you may need other bits for the A post.
Posted 30 March 2015 - 01:38 PM
Nice rot..... 998 turbo will feel slow with all that new metal weight
Posted 30 March 2015 - 05:11 PM
i might cut a wing off to compensate
be proper scene aswell #STANCELYFE!!!
