Hi i have just fitted my center speedo 130mph one. what colour drive that goes into the gearbox for measuring my speed correctly do i need?
thanks
Posted 30 March 2015 - 04:14 PM
thanks
Posted 30 March 2015 - 04:25 PM
All depends on three things..
Speedo TPM ( Written under the odometer )
Final drive ratio
tyre size
and then a calculator...
http://www.guess-wor.../Tech/ratio.htm
Edited by Guess-Works.com, 30 March 2015 - 04:27 PM.
Posted 30 March 2015 - 04:44 PM
Posted 30 March 2015 - 04:47 PM
Posted 30 March 2015 - 04:58 PM
TPM - Turns per Mile
yours is a 1280tpm unit
standard final drive for the metro would be a 3.4, what the gear ratios are does not matter...
are you sure your tyre size is 165/55r12 ? and not 165/60r12
if it's the latter then you will be needing a 6 tooth worm and a 16 tooth pinion for the speedo drives.
Posted 30 March 2015 - 05:11 PM
Posted 30 March 2015 - 05:12 PM
Posted 30 March 2015 - 05:16 PM
Must be using A048R's
in which case you will need a 6 tooth worm and a 17 tooth pinion.
Posted 30 March 2015 - 05:24 PM
sorry im lost with this kind of stuff lol. so the green worm thats in needs changing and also something else? would that require he gearboxed being taken out?
Posted 30 March 2015 - 05:27 PM
The pinion is the plastic one which the speedo cable connects to, the pinion is driven by a worm gear which is driven my the mainshaft in the gearbox. You can change both with the engine in the car, but you will need to remove the radiator and the engine mount and bracket from beneath it to get to the worm drive..
If it has the standard metro drive in there, it'll be a 5 tooth.
Most common of pinions is the 17 tooth so you probably have one already, just count the teeth, don't rely on the colour
Edited by Guess-Works.com, 30 March 2015 - 05:28 PM.
