Assembly Order
8 replies to this topic
#1 Mad Max
Mad Max
  • 306 posts
Posted 19 April 2015 - 11:22 AM
Hello,
I currently have a bare shell and hopefully everything to reassemble. Like a giant lego kit.
Has anyone made a comprehensive list for most efficient assembly order. I.e. I know you need to put the steering rack on before front subframe.
Things like this that mean I hopefully only have to do things once.
#2 corrado vr6
corrado vr6
  • 661 posts
Posted 19 April 2015 - 12:00 PM
Connect the speedo cable to the engine before dropping it in
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 19 April 2015 - 05:30 PM
It all depends on what toots and equipment you have access to, but generally, get it down on it's wheels first with all the brake lines, petrol lines underneath the car fitted and working before... working your way up the car... makes it a lot easier if it's rolling.
Make sure doors, bonnet and boot fit and then remove and stash...
then finish off all the mechanicals, electrics and anything else which involves dirt...
Finally interior.
First thing to make sure is that the body shell is properly ready
#4 Spider
  • 13,929 posts
Posted 19 April 2015 - 09:12 PM
As Guess Works has said, depends on what facilities and tools you have.
I have a 'trolley' for mounting the body to, it brings it up to a nice working height, so for me, the way I usually go about it is;-
Do the interior complete, including wiring loom, trim, all glass, dash, instruments (thought depending on what actual instrumental, this may
          only be a trial fit) pedal box, trial fit the steering column, seats, sound system, carpet etc. for me, next to sorting the shell and paint, this would be the next biggest part,
Engine Bay fittings
Boot fittings, trial fit the fuel tanks, trial fit boot lid
Front to Rear Piping and Battery Cable
Fit doors (build first)
Steering Rack
Front subframe
Rear Subframe
Fuel Tanks
Boot Lid
Fit engine
Drive
Edited by Moke Spider, 19 April 2015 - 09:12 PM.
#5 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 19 April 2015 - 10:51 PM
Mokespider, you've got a Moke, what would you know about doors, boot lids and interiors?
Ha ha ha ha
#6 Spider
  • 13,929 posts
Posted 19 April 2015 - 10:59 PM
Sorry mate!
Correction is in order!!
Ha ha ha ha
I've currently got 8 Minis
I also have a Moke (as does the wife...)
But your post is also what I like about Mokes! No glass, no doors, no trim, no fiddely crap!
#7 peter-b
peter-b
  • 773 posts
Posted 19 April 2015 - 11:01 PM
8 Mini's? You're even crazier than I pictured you. Ha ha
#8 Spider
  • 13,929 posts
Posted 19 April 2015 - 11:11 PM
If I wasn't crazy, life would drive me insane,,,,,  along with the Minis,,,,,  and the missus,,,,,,,,
#9 peter-b
peter-b
  • 773 posts
Posted 19 April 2015 - 11:43 PM
It helps being nuts, one just blends in with all the others.
