Yeah I was actively involved in a lot of these FB pages but I deleted my account and vowed never to return to FB ever again, it was taking over my life LOL
R/c Car.
#256
Posted 07 November 2017 - 10:34 PM
#258
Posted 06 April 2018 - 07:25 PM
Took the Madbull, and 2 of my minis and a newly acquired skate ramp to a local empty car park the other day. With the ramp being intended for the Madbull, but that was until the speedo controller (sealed/waterproof mtronics and auto setting) started acting up and jammed the throttle wide open. So gave that one a miss, although it seams to work fine and then act up, so I'm not entirely sure other than that the esc is stuffed of what's up.
So that just left the two minis, my green bodied basher, mostly made up of parts I had left over/spare, and standard other than some springs and m05 rally hubs for increased ride height. And my more special one with the blue/union jack roof. Still running a standard moor (I put the one from this along with the esc into the Madbull) but oil shocks, M05 rally hubs, f/r anti roll bars etc.
With the green one being the one that just gets abused and always comes back begging for more, I had no problems using it over ramp, or off the side of it onto it's roof when i got it slightly wrong. That was until after about 20 mins the motor was making loads of noise, but there was little to no drive. I feared that I'd finally blown the diff with all the abuse (the gears are pretty worn), But it turned out one of the front wheel nuts had loosened off just enough for the drive pin to fall out and disappear leaving just one wheel drive.
The other one ran faultlessly, other than trashing its front tyres, I just stuck to driving round a few cones. The one issue I did have though and I'll need to check the setup on, is quite violent even when gentle, lift off overseer (think steaming into a corner and yanking the handbrake). Witch if i could catch quickly enough leads to some pretty big fwd drifts or if not, swapping ends and facing in the wrong direction.
Edited by 1984mini25, 06 April 2018 - 08:48 PM.
#259
Posted 06 April 2018 - 08:10 PM
Does anyone have any ideas on what i can change to either stop or make the lift off oversteer iusse more managebale? As the rc mini sits don't seam to be around any more.
From memory its, got soft springs/hard antiroll on the front, and super sort/soft antiroll on the rear, and 2 degree rear toe in uprights.
Oh and i found what was up with the boat not working. The handset/transmitter is stuffed. Probably got wet, but I can't see anything physically wrong with the circuit board inside (bit beyond me), just that it doesn't work. So I spent an hour pulling the working guts from a spare handset with a smashed case and replacing them into the decent one, but with the failed internals/electrics.
Edited by 1984mini25, 06 April 2018 - 08:49 PM.
#260
Posted 07 April 2018 - 08:42 AM
#261
Posted 07 April 2018 - 10:25 AM
This is the esc I was using (with a 20t hpi Saturn motor) and had the full throttle runaway issue with.
http://www.mtroniks....htm#description
#262
Posted 07 April 2018 - 06:37 PM
Ah I see sorry mine must be slightly different . It has a button on that can be used to force a new calibration. It has always been amazing though.
#263
Posted 07 April 2018 - 07:09 PM
Sold two R/C cars within a week. Things you do to fund a turbo project.
And another one bites the dust. Traxxas monster buggy 1/5th gone.
Edited by Anthony30, 08 April 2018 - 01:03 PM.
#264
Posted 07 April 2018 - 07:14 PM
That one in there range doesn't, as it just a budget, plug and play one. The others in the range (and others I have like in the boat) do have a setup button.
But I've never had any issues with the mtroniks stuff (or the rebranded modelsport ones), unless it was interference, but than there wasn't much around that could have. Still I'll give it another try over the field with less things to hit (like curbs) and long grass to run into rather than my ankle.
#265
Posted 08 April 2018 - 07:55 PM
#266
Posted 09 April 2018 - 12:35 AM
I feel you buddy i have 3 really rare ones on ebay right now to pay for a transaxle for a mini build i am planning.Sold two R/C cars within a week. Things you do to fund a turbo project.
A 1/3 scale go kart
A nib yr-f2
And a custom sand rail tube frame Tamiya scorcher
Edited by Mini-dude, 09 April 2018 - 12:36 AM.
#267
Posted 19 April 2018 - 08:00 AM
Blackfoot FPV.jpg 48.44K 1 downloads
Resurrected the old Blackfoot. Now with FPV cam and Fatshark goggles.Great fun !!
#268
Posted 29 April 2018 - 07:23 AM
