Is A Special Tool Required For These Clips?
13 replies to this topic
#1 BusheyTrader
BusheyTrader
  • 484 posts
  • Local Club: Nope
Posted 01 May 2015 - 01:22 PM
Hi,
These clips come with the CV boots supplied by Minispares.
6E77D8C2-7EC3-4A5E-97DD-712B4E4AF9FC_zps
It looks like the tangs on the inner part are supposed to pass through the slots of the outer part. Are you supposed to crimp the looped part of the clip to tighten it? Are you supposed to use a specific tool for it? I'm half tempted to use a pair of strong cable ties instead.
Thanks,
Adam
Edited by BusheyTrader, 15 May 2015 - 10:49 AM.
#2 Ethel
  • 26,786 posts
Posted 01 May 2015 - 01:28 PM
Put 'em on as tight as possible then nip up the sticky out bit with some pincers.
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 01 May 2015 - 01:32 PM
Yea there is a tool for this job Search this number on eBay number 221757458351
http://www.ebay.co.u...1#ht_913wt_1141
#4 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 01 May 2015 - 01:53 PM
nail pincers work well
#5 rally1380
rally1380
  • 1,893 posts
Posted 01 May 2015 - 02:41 PM
For £4 its worth buying the proper tool though isn't it?
#6 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 01 May 2015 - 05:02 PM
Aren't these Oetiker clips. Use these at work.
#7 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 01 May 2015 - 05:10 PM
I tried to tighten these up with a pair of normal pliers - didn't end well.
Ended up taking my outer cv joints and drive shafts to my mate who used the proper tool.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 01 May 2015 - 05:11 PM
Mine are made by nipex, long handles make it easy to squeeze then up, but side cutters could be used with a push
#9 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 02 May 2015 - 08:27 PM
This or believe it or not I have had a lot of success using garden pruners.
Just don't over do it or you will end up cutting through the band.
#10 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 02 May 2015 - 10:25 PM
As mentioned, nail pincers work fine or side cutters used carefully, but personally I'd chuck the clips in the trash and grab some wind up CV boot clips, they not only work better but look neater as well.
The OTK clips as we call them, work great on small hoses and the heavy duty ones on bigger ones but these thin clip together ones really aren't any better than the plastic cable ties. Speaking of which, you can but s/s cable ties which IMO are better than what you have.
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 03 May 2015 - 03:28 PM
In an earlier post you asked about cable ties.  The plastic ones typically don't fit well in/around the hub assembly.  There are low-profile, stainless steel cable ties that are sometimes used to attach header wrap.  They can be used on CV boots as they are much lower.
The old-school DIY way of handling this was to use soft iron wire.  Wrap it around the boot, twist the ends together, cut the twisted end so it was about 3/8" long, then fold the cut end "back" towards the rear of the car when positioned at the "top" of the wheel.
I think that the eBay link shows a great price for the banding tool.  I would certainly buy one for that price.  While the DIY methods and cable ties can be made to work, why not invest a little bit in the tools to do a better job?
#12 minimadles
minimadles
  • 136 posts
  • Local Club: not as yet
Posted 04 May 2015 - 07:36 AM
Although the side cutter method does work the jaws don't close square so can cut through the clip for the cost the correct pliers are worth getting pincers do work but can be awkward to use with the shaft on the car
#13 BusheyTrader
BusheyTrader
  • 484 posts
  • Local Club: Nope
Posted 04 May 2015 - 05:11 PM
Thanks for the help everyone. I've bought the tool as per the ebay link and see how it goes......
Adam
#14 BusheyTrader
BusheyTrader
  • 484 posts
  • Local Club: Nope
Posted 13 May 2015 - 09:36 PM
This is the tool of eBay and it works well with these clips.
F6ACF182-060E-473A-B241-D373BA817FDA_zps
It pinches the top hat portion of the clip from both sides whilst keeping the top in place.
clip fully tightened......
BD98418D-0982-46C3-806C-3A3F36DEDB92_zps
Adam
