I'm planning on overhauling the drive assembly and surrounding bits fairly soon and I'm not sure whether to go all new or if refurbishing some of the parts is a good idea. It's a 94 and I think everything is original on it (has only done 39k so I don't think anything was replaced). Here's a list of what I'm looking at replacing:
- Calipers
- Discs
- Disc shields
- Pads
- Drive flanges
- Hubs
- Steering arms
- Track rods
- CV joints
- Bearings
- Putting in Hi Lo's
- Shocks
- Bushes
I've a few questions:
- Can anyone think of anything else that I should be replacing while I'm at it?
- I had the ball joints done in the last couple of months with genuine parts, can I reuse them or am I better off starting fresh?
- Do steering arms generally become worn/damaged over time? If not then I figure I'll give them a clean up to get the surface rust off and then give them a coat of stone chip and reuse them. They look fine to me but I have little to no experience here.
- Are calipers worth refurbing? Would it be hard/expensive to do myself or have a specialist do it? Was planning on going with minispares calipers but if the originals are as good/better then I'd rather keep it original.
- Is there any reason I shouldn't clean and paint the disc shields and reuse them?
- Is it best practice to change the track rods while I'm down there or is there any point if they aren't causing problems?
- Finally, originally I was gonna go with drilled and grooved discs but I've read in a number of places that standard discs are better (under normal driving conditions) as you get more surface area for the pads to connect with and under normal driving conditions you wouldn't need rapid heat dissipation, does that sound right or are drilled and grooved better? I should say that I don't drive hard at all.
