What Specific Engine Have I Got
Posted 22 May 2015 - 09:01 PM
Would you guys be knowing what specific engine it is?
Posted 22 May 2015 - 09:05 PM
Posted 23 May 2015 - 06:06 AM
Posted 23 May 2015 - 08:11 AM
Where are you? Googling the prefixes suggests it's a 1980 Aussie Moke
Posted 23 May 2015 - 08:16 AM
Where are you?
Nairobi
Posted 23 May 2015 - 08:40 AM
Posted 23 May 2015 - 08:53 AM
Not really. As the info about the Mokes relates to the gear ratios.Am in Nairobi Kenya...that's strange that it says it's a moke
So it might just be an export spec gearbox with a different final drive.
But that is just me making a guess.
Or from one of the links given in the other topics where you have asked this. (Or there are other members on here from Nairobi with the same engine number)
Something to do with Aussie emissions restrictions.
"It is believed the codes relate to engine emission control requirements for Australia."
Edited by nicklouse, 23 May 2015 - 08:59 AM.
Posted 23 May 2015 - 09:31 AM
I'd have to check my records in the morning (our time), but does at a glance appear to be an Aust Moke (and / or maybe a Late Aust Mini) engine no.
I am not sure if we exported Minis to Nairobi, but I do know that we exported Mokes to there, so that may explain it. As Nick has hinted at, the main difference between a Moke Engine and one from a Mini is only the Final Drive Ratio.
I'll check on the number and come back.
Edited by Moke Spider, 23 May 2015 - 09:35 AM.
Posted 23 May 2015 - 11:33 AM
Posted 24 May 2015 - 07:57 AM
It was an engine fitted to the Late Mokes from around October / November 1979 until the end of Aust Production (December 1981).
I don't think it would have had Air Injection, basically a stock 998 as you'd find in most Minis, however the FD ratio would have been 4.2:1. To swap over the FD is a relativity easy job and I'd guess that is what would have been done when it was fitted in to your car.
As I mentioned above, Aust made Mokes were exported to Nairobi, so I'd say that's how it ended up in your country in the first instance.
Edited by Moke Spider, 24 May 2015 - 07:57 AM.
Posted 24 May 2015 - 08:54 AM
Posted 24 May 2015 - 09:50 PM
I would want one more favor from you guys...how can I find out if my mini is an Austin or Morris?
Edited by MiniSingh, 24 May 2015 - 09:52 PM.
Posted 24 May 2015 - 10:16 PM
But then you could look at any badges or any documentation.
But unlikely to be either.
Posted 25 May 2015 - 05:59 AM
Posted 25 May 2015 - 08:02 AM
Neither Austin or Morris existed in 1980, it's BL. It may be called an Austin Rover but that was just a trade name for BL cars ltd. around the time your car was made the organisation changed it's name every few weeks but in reality they were just BL.
My 1980 model HLE Metro, is badged as an Austin Metro, though the Plate on the lock panel says BL Cars Ltd. I also note the owner's book says Austin and Morris on the cover!
I guess it was a time when no one knew who they were working for!
