Adjustable Or Non-Adjustable Suspension?
Posted 24 May 2015 - 10:15 PM
Posted 24 May 2015 - 10:22 PM
Shocks have no bearing on height. The adjustable is in the dampening.you can make it faster or slower.
Yes hi lows can be used to adjust ride height (or correct it) but should be used with some form of adjustable bottom arms and tie are to allow you to correct the geometry.
So what are you considering!
Posted 24 May 2015 - 10:38 PM
Posted 24 May 2015 - 11:06 PM
Every day is a learning day! Well I just want to keep the car stock height but as far as I can see only adjustable cones are available?
Ok so now we have changed from dampers to cones! What ever they might be.
The rubber donuts! They are not adjustable. But do come in a number of flavours.
The trumpets? They come in standard and adjustable flavours.
Posted 24 May 2015 - 11:24 PM
http://www.minispare...LO.aspx|Back to they're called cones there but yes I suppose I should be calling them trumpets (blame mini spares for that). Now I'm not the brightest bulb on the shelf but even I can tell that a rubber cone isn't adjustable! For the rubber cones I'm just going with genuine replacements. Only just spotted the standard trumpets there now so I suppose the question now is should I bother with hi-lo's at all if I'm happy with standard ride height? But is the ride height I have now actually standard or will I find that it's higher once I replace everything due to sagging rubber cones and will I wish then that I had bought adjustable trumpets?
Posted 24 May 2015 - 11:46 PM
Posted 24 May 2015 - 11:50 PM
I suggest you grab the first kit you linked to. It'll allow you to adjust the height to the desired one and also readjust it as the rubber bit (not getting into this one) settles in. Just good non adjustable shocks are fine, that's how they were new so should give good ride and handling without having to fiddle with adjustments. Put all the bits in and get the F&R alignment checked, then go from there as to whether anything else is required.
Sounds like a plan, thanks mate :)
Posted 24 May 2015 - 11:55 PM
Go for some good quality adjustable items to set the ride height exactly the same at all four corners.
