Hi all,
Does anyone know if the centre of the lower plastic steering column bush is meant to be round?
Sounds a silly question but the new one I've got seems to have flat sides to it?
Also how far up do people fit the lower bush into the outer column tube? Haynes doesn't seem to cover the plastic bush only the felt and there seems to be a few notches on the bush to determine how far up to push it?
Thanks.
Steering Column Bushes
Pauly
, May 24 2015 11:07 PM
3 replies to this topic
Posted 24 May 2015 - 11:07 PM
Posted 25 May 2015 - 12:02 AM
Yours may be different to mine but so far as shape goes, yes it is sort of octagonal shape and mine is in flush with end. I put new ones in mine to stop it rattling at idle and not touching s/wheel, it still does. :-(
Posted 25 May 2015 - 10:06 PM
Is it just the case of pushing the bottom bush up using the inner column?
Posted 30 May 2016 - 09:38 AM
Bump anyone?
