Who offers that speedo?
Mini 95 Pickup K1100 Twincam
#136
Posted 10 December 2016 - 03:48 AM
#137
Posted 10 December 2016 - 05:21 PM
Smtihs direct (Caerbont Automotive). Should be here soon! Am excited.Who offers that speedo?
#138
Posted 10 December 2016 - 06:29 PM
The additional gauges all require their own sensors, so I've been busy installing some new shiny bits.
DSN filter head with sensor hole (ignore the dirty engine, it'll be clean soon):
Water temp sensor was a tricky one, so I've opted for an inline adapter and some fresh new 'retro' silicone hoses:
The addition of the above actually means I could do away with a heafty copper pipe the previous owner had used to route water. He'd also cut a notch out of the front panel to do this, so I'll be getting that sorted in the new year.
#139
Posted 23 December 2016 - 09:56 PM
The great news is temperatures all seem good and the pressure shows the same as the ST700 as expected. I now need to set the upper and lower parameters (as well as lights) for each gauge.
CAI (Smiths) are taking their sweet time making the speedo. I guess it'll be the new year for that.
#140
Posted 23 December 2016 - 11:30 PM
#141
Posted 24 December 2016 - 08:31 AM
Currently it's set for water temp and oil pressure. I'm going to change this to fuel pressure and another input (thoughts?). It also is a speedo, volt meter, lap counter, 0-60 recorder and more - it came with the car and is pretty neat.Looking good, what does the digital display in the rev counter show?
#142
Posted 24 December 2016 - 11:10 AM
Air fuel ratio?
#143
Posted 24 December 2016 - 12:29 PM
I've just looked at the price of it because I'm wanting a new rev counter. If it came with the car you've got a great piece of kit, enjoy, just to say, I won't be buying one.
#144
Posted 24 December 2016 - 01:20 PM
that would be useful, I think the ST700 only outputs temp or pressure values though.Air fuel ratio?Currently it's set for water temp and oil pressure. I'm going to change this to fuel pressure and another input (thoughts?). It also is a speedo, volt meter, lap counter, 0-60 recorder and more - it came with the car and is pretty neat.Looking good, what does the digital display in the rev counter show?
#145
Posted 24 December 2016 - 01:22 PM
yeah i'm not sure I'd have gone full bore on the Stack gauges if it hadn't come with the car.I've just looked at the price of it because I'm wanting a new rev counter. If it came with the car you've got a great piece of kit, enjoy, just to say, I won't be buying one.
#146
Posted 24 December 2016 - 05:38 PM
Ah I see. If you want one that changes alot then vacuum could work!
#147
Posted 21 January 2017 - 09:00 AM
It's held in on each end with nuts and bolts. I'll more than likely add a couple of L-brackets in the middle for extra piece of mind too.
Next steps are to remove the lacquer from each glovebox door before painting (still undecided on stain or paint for the back). The whole lot will then be sent off for a good carbon skin
I'm also unsure on whether to put the original domed switch back in the middle. I was planning on using this to power the heater, but unsure if this will make or break the look.
Edited by Richie83, 21 January 2017 - 09:02 AM.
#148
Posted 21 January 2017 - 12:51 PM
#149
Posted 21 January 2017 - 06:00 PM
#150
Posted 21 January 2017 - 07:20 PM
Curious question about your steering wheel setup with the removable boss, do you find that the steering wheel is quite close to your chest?
I had mine setup the same and found it was quite close and didn't know if I liked it that close so took the removable boss off. Been trying to look at low profile bosses but all the ones off fleabay are pretty much the same and after seeing one on a customers car they have way too much play in them.
Bing (2)
