Ride Heights V Tec
Posted 17 June 2015 - 08:26 AM
Posted 17 June 2015 - 09:35 AM
The weight over the front may actually raise the rear a bit as the weight is over the front axle so weight distribution will be heavily weighted to the front.
Posted 17 June 2015 - 10:46 AM
Hi thanks for reply. Dont think I explianed it properly. Ita a rear engines Z car V tec with engine in the back over the rear.
Posted 17 June 2015 - 12:51 PM
FYI, I am running a level floor with 100mm gap to the floor (measured from the car floor, forward of the rear wheels and behind the front wheels).
Tyre sidewall height can play a big part in the gap under the car.
IIRC Z's state that they get better handling with the rear end slung low......
Posted 17 June 2015 - 03:19 PM
Posted 18 June 2015 - 07:11 AM
Cheers that helps. Loved catching up on your build and mag feature. Inspired me to have a go !!
Be prepared for the tears, frustration and heartache.........just don't give up.
If I can help you out at all, with answers, I will endeavour to do so......
