Hi,
I am looking to install an electric fuel pump, most likely a Facet Cube, on my standard road 998 running twin HS2s.
I have done a bit of research in to it (although not very much yet to be honest) but I just thought I would seek advice/guidance/information from you knowledgeable lot!
I am aware, so far, that the pump needs to be mounted as close as possible to the tank with a pre-filter between the two. In this respect - is there any reason why I can't mount the pump in the spare wheel well in the boot?
My main question, really, is what pump do I need to go for?
Also, is there anything that prevents me from running a braided fuel line inside the cabin?
Any helpful comments welcome.
Many thanks,
Dan
TheHippo
