Awesome man! Good work repairing the wheel arches, saved a bunch of money and chopping.
How did you strip the m machine primer? Wire wheel or chemical?
Youre probably right where Im at in the build.
I have been thinking of adding a counter balance to my rotisserie to ease rotation effort, but Im worried about the gross weight on the rotisserie frame, its already split on me once.
I just make do with a long lever arm that goes in the indexing plate that I use to rotate the car where I want it.
I used a wire wheel on an angle grinder, I think it was an old worn knotted wire wheel where the knots were loose. It came off really easy. I've used oven cleaner on a different panel, which worked, but made a huge mess.
My rotisserie is struggling, I believe, and it is definitely not as good as yours. Lets face it, mine is a functional hack job! Made mine from engine stands and the long post is 2 pieces of angle iron fashioned together with metal screws. I built better legs, for rolling around the yard, but indoors, I chopped them and made some dodgy , narrow wood bases so I could turn it lengthwise around my work space( which used to be my bedroom-ha!) After tack fitting the floor, it got really heavy.
I thought of doing something with bike chain and gears to spin it, but I just spin it slowly and as carefully as I can.
