After sourcing the correct 1st motion shaft (with the bearing situated deeper than the later 3 sync ones), I am having trouble finding the correct bearing to fit.
The mainshaft has a 1/2" (ish) shank for the 1st/3rd motion nose bearing to sit on; the later 3 sync has a larger shaft. On the minispares website, the technical drawings seem to display the bearing I need, however it has the same part number as the one I don't want. The photo and measurements also confirm it to be incorrect.
Does anyone know where to find this bearing, or at least know what I'm on about? I might give guessworks a try.
Edited by Stiggytoo, 28 July 2015 - 08:50 PM.
