Help Sourcing Very Early 3 Sync 1St Motion Bearing
11 replies to this topic
#1 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 28 July 2015 - 07:20 PM
Currently building a 3 synchro gearbox. From what I understand it's quite a early one, but fundamentally the 'b type' 3 sync box? - The gears on the mainshaft run on bushes with oil grooves etc.
After sourcing the correct 1st motion shaft (with the bearing situated deeper than the later 3 sync ones), I am having trouble finding the correct bearing to fit.
The mainshaft has a 1/2" (ish) shank for the 1st/3rd motion nose bearing to sit on; the later 3 sync has a larger shaft. On the minispares website, the technical drawings seem to display the bearing I need, however it has the same part number as the one I don't want. The photo and measurements also confirm it to be incorrect.
Does anyone know where to find this bearing, or at least know what I'm on about?  :P  I might give guessworks a try.
Edited by Stiggytoo, 28 July 2015 - 08:50 PM.
#2 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 28 July 2015 - 07:35 PM
http://www.ebay.co.u...=item419a25b275
think its this box.
any earlier and there very rare as there the magnesium casings
this is a 1960 box if my memory is correct
the mag casings are 1959
#3 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 28 July 2015 - 07:44 PM
2a3708 first casing. 22a104 second casing. 22a145 third casing.
All these had cone brass synchos.
Think they all had the same laygear.
What casing is urs
#4 Spider
  • 13,929 posts
Posted 28 July 2015 - 08:13 PM
Just to throw another bearing in to the mix, I also have a listing for a 2A3709.
I haven't had much to do the 3 Scynchro Boxes, but just checking through the factory info on them there is no noted change of the first motion shaft bearing until the introduction of the all synchro box, however, I'm fairly sure that's incorrect.
GW will know.
#5 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 28 July 2015 - 08:49 PM
I'll have a look tomorrow at the casing and take a photo or two. Cheers
#6 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 29 July 2015 - 09:32 PM
Can't be bothered to upload photos atm, but the gearbox casting is 22G68.
#7 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 29 July 2015 - 09:38 PM
Ahh, think I've found my answer :/
An extract from a minispares article: "The A type 3rd motion shaft (main shaft) has a smaller nose to accept the 1st motion shaft which has a fixed sleeve bearing which is obsolete and not replaceable."
#8 Spider
  • 13,929 posts
Posted 29 July 2015 - 09:51 PM
The Bearing you are after (1st Motion Shaft Bearing to suit the 22G68 Case) is the 2A3709.
If your stuck getting one, send me a PM.
Edited by Moke Spider, 29 July 2015 - 09:53 PM.
#9 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 29 July 2015 - 10:30 PM
Are you sure? A quick search returns 3 sync single roller which isn't what I'm looking for.
#10 Spider
  • 13,929 posts
Posted 30 July 2015 - 03:15 AM
Ah, OK, so it not as per your topic title then.
Here's a couple of pages from the parts book;-
So which bearing / part are you after?
#11 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 30 July 2015 - 09:12 PM
I believe I'm after no. 21
#12 Spider
  • 13,929 posts
Posted 31 July 2015 - 12:28 AM
Ah OK, got ya now!!  Factory call it Bearing - Needle Roller - Third Motion Shaft, however it;s probably more commonly known as a 3rd Motion Shaft Nose Bearing.
It's a 22G314, however I'm hitting brick walls on it.
Try GW or if you can accurately measure the shaft OD and length and 1st motion shaft ID we'll see if it can be tracked down.
Or try these guys;-
http://www.bearing-s...AR LISTINGS.htm
Edited by Moke Spider, 31 July 2015 - 12:33 AM.
