Hi all. I just found the spec sheet for the camshaft fitted to my modified 1293 engine. I'd like to know what exactly it is.
The info I have is below;
Grind: Speco 4LA417
Cam lift 0.294
Valve lift 0.350
Duration: 290 for Inlet and Exhaust
Inlet opens 38 BTDC, exhaust 76 BBDC, overlap 72
Inlet closes 72 ABDC, exhaust 34 ATDC
The cam is street friendly with very good low down torque, pulls away from 1500 rpm. I'm curious to know what this cam is equivalent to as I'm tossing up whether to change it. (Gearbox has to come apart due to dodgy batch of synchros). The engine has a highly worked head (11:1) running with a 45 weber, LCB and close ratio gearbox so it should be suitable for coping with a hotter cam.
Wondering what people's opinions are and what cams you are using for a similar spec engine.
I don't want a pig of a car down low but would like to use a cam that is appropriate for the engines potential. (In a previous life I had a car with a 649 cam that was fun but tedious down low. I lived on a steep hill and the only way to get the thing going was to spin the wheels..)
Thanks for any comments..
Mikal
