Millers Oil In S/c Engine
11 replies to this topic
#1 maccers
maccers
  • 1,829 posts
  • Local Club: LSMOC
Posted 06 August 2015 - 10:58 AM
Am currently using Millers 10w/60 oil ->  http://www.millersoi...ctor=Motorsport in my 1293 supercharged engine - is it correct?
#2 mini13
mini13
  • 3,805 posts
Posted 06 August 2015 - 12:00 PM
just use millers CTV, its meant to be used with the A series gearbox.
#3 maccers
maccers
  • 1,829 posts
  • Local Club: LSMOC
Posted 07 August 2015 - 12:32 PM
Thanks for that, will do. I only ask as I know fully synth is no good and noticed that the Millers 10w/60 I have is fully synth (and quite pricey).
Also when I floor the car I get lots of light blue smoke - perhaps the oil is too thin. Engine only done 2000 or so miles since rebuild (1275 to 1293 S/C + twin point jnjection)
#4 jaydee
jaydee
  • 8,565 posts
Posted 07 August 2015 - 02:09 PM
That 'fully synth is no good' is just a myth, you have a rebuilt SC engine, a synth oil will be the best choice for it.
Although Millers tend to not last long, the oil gets thinner after 1 or 2 thousands miles. Keep an eye at oil pressure.
#5 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 20 August 2015 - 07:00 PM
10w 60 is not viscous enough you need a good quality 20w 50 semi synthetic like this - http://www.minisport...0-5-litres.html
Supprised you don't beat the syncro using 10w 60
Edited by HUBBA.HUBBA, 20 August 2015 - 07:01 PM.
#6 mini13
mini13
  • 3,805 posts
Posted 20 August 2015 - 09:19 PM
erm, 60 is thicker than 50.
#7 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 21 August 2015 - 09:13 PM
Sorry, wasn't thinking. You still need 20w 50 though. What was your running in proceedure?
Edited by HUBBA.HUBBA, 21 August 2015 - 09:15 PM.
#8 maccers
maccers
  • 1,829 posts
  • Local Club: LSMOC
Posted 01 September 2015 - 01:26 PM
Engine is new and requires running in : first 300 miles up to 4000 rpm light loads , then oil change for 20/50w oil,300-7500 slightly more load up to 4500 rpm , oil/filter  change  to 10w/60 millers oil and return for full map and rolling road test.
That was the running in advice I got and followed.
#9 jaydee
jaydee
  • 8,565 posts
Posted 01 September 2015 - 02:49 PM
Always follow engine builder indications.
Whats missing is the service interval after run-in. Just dont expect millers 10w60 to last as long as you expect from a modern synth oil, it still needs frequent change if you do motorway trips or track days, and thats pretty much normal for a performance a series engine, either you use millers or other brands.
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 September 2015 - 04:53 PM
Don't forget Millers CTV is a competition grade oil, so designed for competition, this does not mean it is best designed for a road car...
Millers also do a 'Mini oil' which is 20w50 Mineral..
But bottom line, use your own choice of oil and change it regularly, as you have already noticed with your 10w60, looks like a service interval of 2k is required.
#11 gazza82
gazza82
  • 2,919 posts
  • Local Club: TMF+
Posted 01 September 2015 - 06:46 PM
I think with the Mini the key is the gearbox ... and the metals used for bearings, etc. Some synth oils contain additives that aren't friendly to some metals. Mineral oil is fairly basic.
On my online A-series I plan to use 10W40 or 10W50 synth in the newly built engine (after running in with 20W50) but stick to 20W50 in the separate gearbox due to the material used in some bearings.
#12 maccers
maccers
  • 1,829 posts
  • Local Club: LSMOC
Posted 02 September 2015 - 07:47 AM
To be honest I do a yearly service on most fluids anyway, as the car might do less than 1000 road miles per year and no track work etc.
