Got two good days at the mini this weekend. A little short of photos as I forgot to take any.
Managed to fit both outer seals, replaced the passenger door step and corrected the gaps.
Re-skinned the drivers door, their is a small crease and some ripple along the lower edge nothing a little filler and attention won't sort out but I am pleased with end result.
Fixed the passenger side scuttle panel and had to make a filler panel as I cannot for the life of me find the original. It will turn up I'm sure at some point.
Seam sealed most of the under side and cleaned up some of the duff weld seams.
Following the issues I have had with the heel board we test fitted the rear sub frame and with a little adjustment it fits so i am happy to get on and spray the underside and get a coat of stone chip once i finish the drivers scuttle panel repair and filler panel.
Good weekends work thanks to my son and Grumpy!!
