Micra Conversion Parts
Posted 11 September 2015 - 07:59 PM
Here is the new plenum!
Posted 11 September 2015 - 08:58 PM
Posted 11 September 2015 - 09:45 PM
Posted 20 September 2015 - 11:02 PM
Looks great, I will be doing a Micra conversion, getting my engine out on Thursday. How much would these cost?
Would try it my self but I have no way of welding stainless yet.
Edited by ninham, 20 September 2015 - 11:04 PM.
Posted 21 September 2015 - 05:44 PM
Will be great to get a decent exhaust manifold made for these conversions.
Plenty of people have used the standard alternator though.
Posted 26 September 2015 - 06:38 PM
Hi, how much for the intake and exhaust manifolds? I won't be using a servo so don't need a servo take off on the intake. What fuel rails and throttle bodies can be fitted to it? Does the exhaust come with a place to screw in the lambda? Full decat/sits close to the engine? What is the diameter of the exit pipe?
Posted 26 September 2015 - 07:02 PM
You will have to provide your inlet mainfold for him to use the flange off it.
Posted 06 October 2015 - 03:13 PM
Pretty sure it it you would need to be set up for aluminium welding not stainless.Looks great, I will be doing a Micra conversion, getting my engine out on Thursday. How much would these cost?
Posted 06 October 2015 - 09:53 PM
Sorry for the delay in replying, for some reason none of these replies flagged up on my alerts! The price for these start at £270. I have the details on my website of different option. Custom setups also welcome.
Edited by matty..., 06 October 2015 - 10:12 PM.
Posted 06 October 2015 - 09:57 PM
Looks good!
The exhaust manifolds are in progress, I should have the first one finished this week. This is going into a Micra to be later fitted into a mini. This will be made to run with a 1 3/4" system, but it is possible to make it to fit a 2" system.
Posted 06 October 2015 - 10:06 PM
Plenums start at £270, and as 666junky says it allows fitment of all the standard injectors,fuel rail and throttle body. The Vacuum takeoffs can be made to suit your requirements on these, most have 2 x 10mm and 2 x 6mm take offs. I have made these for both type of throttle body now, the throttle bodies are quite different on the later engines, but the mounting flange is very similar. They can also be made to suit any other aftermarket throttle body, but for aftermarket throttle bodies, I would need the throttle body to make sure the fitment is correct.Hi, how much for the intake and exhaust manifolds? I won't be using a servo so don't need a servo take off on the intake. What fuel rails and throttle bodies can be fitted to it? Does the exhaust come with a place to screw in the lambda? Full decat/sits close to the engine? What is the diameter of the exit pipe?
The exhausts have a built in lambda boss on the side (not in picture above) and should have 35mm clearance on the front panel using an Allspeed subframe. I will confirm this when the first manifold is fitted up. price is yet to be confirmed, they'll be around the £450 for the manifold and link pipe to join onto a standard mini centre section.
Edited by matty..., 06 October 2015 - 10:10 PM.
Posted 07 October 2015 - 06:58 PM
On your website what's the difference between with trumpets and without. What are the trumpets?
Just starting my conversion and interested
Posted 07 October 2015 - 09:43 PM
Edited by matty..., 07 October 2015 - 09:43 PM.
Posted 11 October 2015 - 06:45 PM
Edited by matty..., 11 October 2015 - 06:46 PM.
Posted 06 November 2015 - 10:12 AM
