Are these the SickHID's? I want these but with shipping for the U.S they are a tad expensive, don't we have an British version somewhere in the UK?
Posted 23 December 2015 - 06:01 AM
Hi everyone!
This is my first post!
I could not find an exact answer online and had to ask the PRO's
Does anybody know if Jeep Wrangler headlights fit? I am guessing all 7" fit but I don't want to buy them just to find they don't.
Thanks in advance!
The answer is "most". There are some that are made specifically for the newer wranglers and they will have a different electrical connector. As for the size, yes, all Jeep wranglers of the correct years will use a 7" round headlight. Jeep YJ' used rectangular headlamps.
Posted 23 December 2015 - 09:45 AM
Hi everyone!
Thanks in advance!
Ah Brilliant so these should work?
http://www.ebay.co.u...bUAAOSwLVZV3ZJX
I am not adverse to cutting the connector off and wiring this in to the mini - as long as it fits!
Any objections??
Thanks all,
Posted 24 December 2015 - 10:28 PM
Posted 26 December 2015 - 01:46 AM
Stewi, DO NOT BUY those headlamps. They might fit, but they are a Chinese knockoff of the real deal. There is a reason they are so much cheaper. They suck.
If you're really looking at going with LED headlights, watch this series on Youtube first.
7" Round LED Headlight Shootout
You will be very disappointed with that headlight and you'll just wish you had bought something a little nicer. If you're looking to get LED headlights, I would recommend getting nothing less than the Truck-Lite 27270C headlights.
My next set of headlights will either be a custom LED retrofit or a set of off the shelf very high quality LED rounds like the JW Speaker EVO2's. With things like lights that allow me to see others or others to see me, I don't usually skimp. When you go cheap you can do one of many bad things. Not enough light to see hazards, Not enough light to safely be seen from the rear, or your light is not aimed/cut-off properly and you will blind oncoming traffic.
Posted 26 December 2015 - 08:40 AM
Posted 26 December 2015 - 03:20 PM
Posted 26 December 2015 - 03:50 PM
I've got LED bulbs in all the lights on the front of my mini. Makes driving in the dark a much more pleasant experience
What headlight and globe combination are you using? Just curious, because I'm considering the LED bulb route as well.
Posted 26 December 2015 - 04:53 PM
Posted 26 December 2015 - 06:20 PM
If you're serious about the conversion and you want to get good, professional quality without blinding traffic, you're pretty much stuck spending a few hundred dollars. The best option, in my opinion, if you don't want to do the work yourself would be paying a high quality retrofitter or buying the Morimoto Sealed 7's.
The SickHID's retrofits are ok. I think he's using the Mini H1 projector which is a decent projector. I'm not sure what he's charging for them.
My setup by itself (just in parts) cost me a few hundred dollars in parts. You will pay for quality when it comes to lighting.
Posted 26 December 2015 - 10:03 PM
Posted 26 December 2015 - 10:15 PM
Surely sealed beam LED units are where its at in the UK? E marked, no need for self levelling, a lot better than non e marked led replacement bulbs, used in a lense not designed for an led output?
Posted 26 December 2015 - 11:33 PM
Posted 26 December 2015 - 11:36 PM
How is a unit designed for a replacement bulb? My headlights still have the standard pattern and you can't tell from the outside that they're LEDs. The MOT is due next month, will see if they pass!
