good idea about wrapping the window strips i also have the black window filler strip and dont need to worry about the petrol cap :)I'm doing the same with mine and having no chrome, even got the black screen rubber insert. I'm going to wrap my window strips and paint everything else including the polished filler cap
Meet Eko
rhys-89
, Sep 21 2015 08:54 PM
554 replies to this topic
#496
Posted 24 December 2016 - 10:46 PM
#499
Posted 26 December 2016 - 11:33 PM
Tonight me n the old man had few hours in the garage so set to work and removed the iseats and roll cage then preped primed and painted the parts on show inside then set to fitting the headlining. All in now and just needs trimming up on outer edges. Also primed and painted one part of the roll cage to see what itll look like.
#500
Posted 28 December 2016 - 06:46 PM
Looking very good rhys keep up the good work mate. Cheers Tom
#501
Posted 28 December 2016 - 06:51 PM
Thanks tom tonight should see the cage sprayed the carpet fitted and cage fitted . fingers crossed
#502
Posted 28 December 2016 - 11:54 PM
Well tonight went well i covered the cross member with material then the rear arches i then fitted the rear door cards and seat. During this time i rubbed down primered and painted the cage. I then painted the hand brake and gear stick purple then fitted the front carpets. And have fitted the roll cage back in finger tight for now. Tomorrow evening should see the interior almost complete.
#504
Posted 01 January 2017 - 01:55 AM
The clock is where it is as its next to the webbers box. Also rubbed the glue of the visor frames and painted them up. Fitted gear gator and fresh air duct to heater.
#505
Posted 03 January 2017 - 11:05 PM
Not much of an update but battery ran flat and i struggled to get to the batrery with a jump pack as i had to use the speaker hole in the parcel shelf. Because of the electronic boot lock. ( this in mind for future ) i have now fitted a fly lead from the + side of battery through the seat back and under the base cushion of the rear bench seat. I used a spare 60a fusion subwoofer inline fuse holder with fuse removed to seal the live end. So access is now just lift the bench seat base to get to positve of battery.
#506
Posted 04 January 2017 - 12:02 PM
Looking really good mate!
#508
Posted 19 February 2017 - 10:42 PM
Tonight me n the old man got eko running and adjusted the webber a little nice to hear him running after sitting un touched for a few months. Will be back on him soon once miffys finished.
