Meet Eko
554 replies to this topic
#541 Midas Mk1
Midas Mk1
  • 5,626 posts
  • Local Club: S.U.N.M.C
Posted 04 May 2017 - 09:15 AM
For the cam locking tool, can you not just cut half of the cambelt off, slide the new one over, then cut the half-original free? Just a thought
Pretty sure there's another way on the B series to lock the cams without a tool, IIRC watching one of Danny DC2's vlogs on youtube I saw it done on  his old black DC2 (using a drilbit?).
Edited by Midas Mk1, 04 May 2017 - 09:34 AM.
#542 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 04 May 2017 - 11:45 AM
@15:30ish!
#543 rhys-89
rhys-89
  • 1,549 posts
  • Local Club: minifreekz
Posted 04 May 2017 - 04:00 PM
Thanks guys will look Into it but I also need to change the water pump so cutting belt in half maybe an issue ?
#544 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 04 May 2017 - 07:59 PM
The problem you seem to have is the cambelt is not tight, so which is the correct position to set the cam gears to. Your safest option is to time it up correctly. If you do that you'll know you won't be kissing pistons with valves.
#545 rhys-89
rhys-89
  • 1,549 posts
Posted 04 May 2017 - 10:39 PM
the pics of the belt were just to show the slack in it if I take it around to tdc on pully to casing the cam notches are spot on inline after watching the video think I'll have to get some 5mm drill bits out
Edited by rhys-89, 04 May 2017 - 11:32 PM.
#546 rhys-89
rhys-89
  • 1,549 posts
Posted 05 May 2017 - 08:01 AM
This morning before work I set it to tdc got my self 2 drill bits as per video and hey Presto straight through the top plated and located into both cams. I have cancelled the key lock order from h-tune. And will be changing the belt pulley and pump tonight. Thanks danie garry for the video link and hopefully saving me pennies if h-tune refund me as they still haven't dispatched it yet ;-)
Edited by rhys-89, 05 May 2017 - 08:03 AM.
#547 rhys-89
rhys-89
  • 1,549 posts
Posted 05 May 2017 - 11:48 PM
Well tonight I removed and refitted pully new cambelt and water pump.
Also as I'm not running the ac pump or power steering pump so i cut down the bottom pully from 3 to 1.
20170505_194647.jpg20170505_205510.jpg20170505_205436.jpg20170505_210529.jpg20170505_213304.jpg20170505_220817.jpg20170505_231636.jpg
#548 rhys-89
rhys-89
  • 1,549 posts
Posted 17 May 2017 - 10:08 AM
Had my new interior door cards and cover turn up for autostitch the other day. Lack vinyl with lime green stitching.
Also my skunk 2 pro turned up from h-tune yesterday.IMG_20170516_171420_797.jpg
#549 rhys-89
rhys-89
  • 1,549 posts
Posted 17 June 2017 - 10:12 PM
Soooooooo after 9 weeks of waiting on Thursday this lovely little lot turned up all speed frame. Heavy duty mini pots heavy duty Honda to mini drive shafts and all speed heavy duty bottom arms and tie bars.
as I knew I would be waiting a while I decided to do another mini project which is close to the finishing line but is now in the way of ekos Honda swap and other body mods.
#550 rhys-89
rhys-89
  • 1,549 posts
Posted 19 July 2017 - 02:15 PM
Well I have managed to progress some what with the allspeed frame in the last two evenings I have stripped tagged and sprsyedthe frame. Shot blasted and painted components and started to 're fit to frame with new bearings and ball joints and other bits bobs 20170715_201231.jpg20170715_210754.jpg20170715_212854.jpg20170715_221435.jpg20170717_193239.jpg20170717_210914.jpgIMG_20170717_231100_272.jpg20170718_230918.jpg20170718_230933.jpgIMG_20170718_231716_225.jpg
#551 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 14 August 2017 - 09:04 PM
Looking great, lovely paint job on the front frame.
#552 rhys-89
rhys-89
  • 1,549 posts
Posted 14 August 2017 - 09:27 PM
Thanks car has progressed alot since engine in frame and in car cut the box in the bulkhead for the intake manifold and have now removed front assembly ready for finalising welding on the bulkhead box and then paint it All ready to 're fit the subframe and engine.
#553 rhys-89
rhys-89
  • 1,549 posts
Posted 14 August 2017 - 09:34 PM
#554 rhys-89
rhys-89
  • 1,549 posts
Posted 14 August 2017 - 09:36 PM
#555 rhys-89
rhys-89
  • 1,549 posts
Posted 18 August 2017 - 05:40 AM
Sooo I cut out the bulk head welded in a box prepped and painted the bulkhead. Fitted a new steering rack and 're fitted the engine and frame. And I can now proceed with final assembly prepping and painting components as I go. Pics so far
20170816_212135.jpg20170816_212122.jpgIMG_20170816_220300_895.jpgIMG_20170817_182551_796.jpg
