Micra Exhaust Dimensions
14 replies to this topic
#1 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 29 September 2015 - 08:26 PM
I am currently making an exhaust for someone doing a Micra conversion, and I am after a measurement if anyone can help that has the engine installed in their mini already. I have the original manifold to jig from, but I would like to know the distance from the exhaust gasket face to the front panel, with the engine fitted with an Allspeed subframe? Any help would be much appreciated, and I get my jig finished for these!
#2 matty...
matty...
  • 605 posts
Posted 30 September 2015 - 08:12 PM
This is the manifold I have made, but I need to check the clearance on the front if anyone can help?
36fdf98a51cdcd723d54a1f8aafd7c04_zpsmxqu
ecf2a448881fb27dff98b6e120c7a8fa_zpsraqf
#3 fuzzy-hair-man
fuzzy-hair-man
  • 181 posts
  • Local Club: Minis in the Gong
Posted 01 October 2015 - 01:05 AM
Nice looking exhaust!
I don't have an allspeed frame but with the lack of other replies... (my engine may be further forward but I doubt it)
My exhaust is a 4-2-1 so two pipes head down under the sump which effects what I can do.
I have my pipes sitting less than 5mm from the side of the block where it joins the sump but even with that I've had to cut 1cm or so out of the front panel for clearance.
That said your 4-1 looks to work better as you can probably put the pipes closer to the block as they won't have to make the bend around under the sump.
The bit that has clearance problems for me is middle 2 pipes as they bend downwards as I put the engine/subframe in (my engne and subframe go in from the bottom). As your extractors collect above the sump/block webbing I'd move the pipe turning from vertical to go under the sump as close as possible and use that to get the whole thing as close to the block as possible.
The furthest out my extractors come from the head where they mount is about 135mm.
Hope this helps
#4 Artstu
Artstu
  • 832 posts
Posted 01 October 2015 - 09:37 AM
Nice manifold for a Micra that doesn't have a top mounted alternator. However for a Mini  I think a radical change will be needed, there's not a lot of room.
#5 Artstu
Artstu
  • 832 posts
Posted 01 October 2015 - 09:49 AM
#6 Artstu
Artstu
  • 832 posts
Posted 01 October 2015 - 09:53 AM
Actually those last two were unmodified
#7 matty...
matty...
  • 605 posts
Posted 01 October 2015 - 11:54 AM
Thanks for the replies, much appreciated. That Info is just what I needed to know. I have kept the primaries short, so the down pipe joins before the subframe, so I can tuck the pipe tight into the sump recess. The setup measures 100mm fro. The flange face to the furthest point on the collect so that should clear by at least 35mm on those measurements.
Any pictures of your setup with the alternator in place? If I need to move primary no.1 over now is the time, before its all welded up.
#8 Artstu
Artstu
  • 832 posts
Posted 01 October 2015 - 12:17 PM
To my knowledge no one has gone for a top mount alternator on a Mini. Only the air-con Micras have it there. I'd imagine there will be a small market for the manifolds from Micra owners.
I'm doing a slight variation with an A-series Metro subframe, but may have to put the alternator lower down anyway.
Attached File  metro micra.jpg   48.61K   12 downloads
#9 matty...
matty...
  • 605 posts
Posted 01 October 2015 - 02:19 PM
Thanks for that pic. That doesn't look to be an issue with the way I currently have it. I'll get cracking on with it.
I guess most people are using a 1 3/4 system on these engines?
#10 matty...
matty...
  • 605 posts
Posted 11 October 2015 - 06:50 PM
I have this all welded up now, ready for its trial fitment. It's quite a bit more compact than the original, so I am hoping for plenty of clearance all round....Thanks for all the dimensions and pictures, they've helped very much! I started a thread on the Traders section about this, so I will update the fitted pictures on there shortly!
34ab40bfb6ec4752d80e0904069d8acd_zpsqf4m
13f4e41d8a7ca33ea1443c314799b25c_zpsm9nx
4239f6875e6fc4a79b8aa7c77c1afa2a_zpswxr0
#11 StewartB
StewartB
  • 93 posts
Posted 25 October 2015 - 09:09 AM
matty ive not been on in a while (minis been stuck in a corner of the workshop untouched past 6 months) if you need measurements give me a shout. im running a top mount alt from a suzuki swift, and may be interested in manifold as well.
#12 thelegg
thelegg
  • 608 posts
Posted 27 October 2015 - 07:14 PM
Will you be making more of these to sell ?
#13 matty...
matty...
  • 605 posts
Posted 28 October 2015 - 03:13 PM
The guy I made this exhaust for has had his mini stolen, so he has decided not to continue with his build, so a I'm happy to sell this one cheaper for someone that is willing to trial fit.
I have built a jig around this manifold to put into production, but I need to check the fitment first before I commit to making a run of them. If someone would like this one and in the position to fit now, just let me know.
#14 StewartB
StewartB
  • 93 posts
Posted 28 October 2015 - 08:16 PM
matty mail me a price, im going to get one done at some point or the other anyway!
#15 matty...
matty...
  • 605 posts
Posted 29 October 2015 - 07:54 PM
Sent you a message on facebook Stewart.
