Corrugated Cement Roofing Sheets
9 replies to this topic
#1 brownspeed
brownspeed
  • 451 posts
Posted 02 October 2015 - 09:09 AM
I'll be removing my garage roof soon- to be replaced with an insulated version using coated steel sheets, thus the original concrete sheets will besurplus. Anyone want some sheeting?- ideally all of it!. the garage is approx 21` x 10.5` wide.
Obviously buyer collect; south manchester
#2 brownspeed
brownspeed
  • 451 posts
Posted 08 October 2015 - 10:08 AM
Roof is coming off this weekend.
Thats settled it then; no need for me to be taking care removing them.
#3 Udo
Udo
  • 1,670 posts
Posted 08 October 2015 - 11:20 AM
You do know they will be ASBESTOS sheets
Please dont go smashing the sheets I know there is minimal fibres in them but there is still some. Undo/grind the bolts off and remove in one piece
#4 brownspeed
brownspeed
  • 451 posts
Posted 08 October 2015 - 02:47 PM
I know they aren't asbestos as I bought them back in 1992. They're corrugated cement as opposed to corrugated asbestos cement- which i think was outlawed before `92.
Thanks for the concern and the advice though; luckily I know what i'm doing - I work in the petrochemical industry where asbestos legacy equipment can stil exist. i'll still be as careful as i can to avoid having to sweep up!
the next hard bit is convincing the council that they aren't asbestos so I can safely dispose them.
PS- i wouldn't have offered them on here had they been asbestos.
#5 mm man
mm man
  • 398 posts
Posted 08 October 2015 - 08:24 PM
I fitted my steel sheets on top of the cement ones as the steel one need a layer underneath to stop condensation. Has been fitted for 15+ years and also acts as a good insulator
#6 acrowot
acrowot
  • 278 posts
  • Local Club: manchester minis
Posted 08 October 2015 - 10:10 PM
you will have to wrap them like they are asbestos to take to the tip I had the same problem at my local tip
#7 brownspeed
brownspeed
  • 451 posts
Posted 09 October 2015 - 04:34 PM
The cement sheets also were condensing-so I'm going with Plywood, plastic layer, insulation, another plastic layer, then the steel sheets.
I like your thinking mm;- I would have considered your idea except  now already have the materials. If I laid all these on top of the existing cement sheets the roof would probably be so high it'd block out the light in the garden!!
#8 Daz1968
Daz1968
  • 2,058 posts
Posted 10 October 2015 - 08:45 AM
I have plywood inside, with rock wool insulation above this then a small airgap followed by plastisol sheet, have never had any condensation or damp in the garage at all, so I can agree its best way
#9 blacktulip
blacktulip
  • 6,221 posts
Posted 10 October 2015 - 05:58 PM
I just flexacryl'd my roof sheets today and sealed all the gaps up inside with silicone. Once I know its water tight I will be suspending 25mm celotex between the beams. Then a lick of white paint on the walls and ceiling will be ok I hope.
#10 brownspeed
brownspeed
  • 451 posts
Posted 16 October 2015 - 08:49 AM
GONE! collected last night; please can someone lock or delete this now. Mini thanks
